Question about Jensen VM9510 Car DVD Player
Whats the code sequence?
How do i bypass the brake on the jensen vm-9511tsx?
  • naruto1982 Mar 10, 2008
    thanks to anyone who helps
  • Anonymous Apr 13, 2008
    I put bypass code in and the screen played the dvd 4 about 5 sec then da parking break screen came back up... Did i put da code in wrong???
    Problem Solver:
  • 5 Answers
All you have to do to bypass your brake is insert a DVD into the dvd player. When the blue screen pops up just take your remote and press stop stop 1,2,6,4 that will bring up a manufacturer menu that you wont be able to see. Once you do that use your right joystic and press down then right that will turn the brake override on and also make the brake wire completley useless. then you want to set the region code to 1 and turn the macrovision to off. Once you do that all you have to do is press SYS SETUP on your remote control twice to save the settings. Thats it you are all set you will never have to worry about the brake again and you can watch the movie while driving but be careful if you drive eratic and get pulled over with a movie playing its a big fine. Enjoy!
Posted on Apr 23, 2008
Whats the brake bypass code for jensen 9215bt
I have no idea what you are talking with the "code". It's a Jensen!!!Attach the parking brake wire to ground and watch a movie.
Feb 11, 2013 | Jensen Car Audio & Video
How to bypass a park switch for a jensen model VM9212N
go to settings menu, and highlight language button. and on your remote enter 543210 in sequence. then another menu will pop up. Go to the settings menu and then the second one down will be the brake option. then click which setting you want
Feb 15, 2009 | Jensen Car Audio & Video
Help need bypass code or instructions
There should be an extra wire on your wiring harness, labeled for the e-brake light. Find that one. On my Jensen, it's a peach colored wire. In your manual, take a look and see what it says is required for activating the DVD playback feature. If you simply have to pull the brake handle to make it work, then yes, just ground that wire and you're in business.
On my Jensen, there was a sequence that had to be done - the brake had to be applied, released, and reapplied for it to work. What I did initially was to ground the wire and put a switch inline on it. To simulate setting the ebrake, I'd close the switch (completing the ground), then flip it open to break the connection (same as releasing the brake), then flip it back again, and the DVD would play.
I found a little while ago that there is a hidden feature menu on the player that allows the e-brake sequence to be bypassed with a code, which I put in and now it's not an issue.
Take a look at your instruction manual and let me know if it just has to have the e-brake on, or if there's some sort of activation sequence like my Jensen has, and I can firm up the answer.
Dec 26, 2008 | JC Whitney - Pyle 7" Tft/lcd In-dash...
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
Hooking up the parking brake sequence
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 11, 2008 | Jensen VM9510 Car DVD Player
Jensen Vm 9512
if you want to play dvds well you drive you just need to put parking brake wire (pink) to ground no code needed
May 25, 2008 | Audiovox VM9512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
Jensen VM 9022
Access the setup menu and while there put in security code on remote, 012345, or 543210. Once entered you will gain access to the secret menu, scroll down to the braking option and select the brake off option. Enjoy....
Nov 30, 2007 | Jensen Car Audio & Video
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
isn\'t there a way to bypass the parking brake so my video plays anytime i want
Dec 15, 2006 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
80 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
