Question about IBM ThinkPad T30 2366 Notebook
Ac adapter problem
Ac adapter to my ibm t30 seems to be not working. when I plug in the adapter to laptop I see a battery icon on the task bar. I checked with my friends adapter no battery icon on the task bar. so, my adapter broke. it it happens.
    Problem Solver:
  • 29 Answers
Buy a new T30 adapter off ebay, they are cheap enough and you could probably get OEM if you know where to look.
Posted on Mar 11, 2008
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
The t30 light goes immediately from green to orange and won't power up. I just replaced the fan
Remove all power sources(battery and AC adapter) from the laptop. With the power source out, press and hold down the power button for 15 seconds. Then, power on the laptop using the AC adapter only. If this does not work, issue might have something to do with the motherboard.
Jun 09, 2010 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
Apr 26, 2009 | IBM Thinkpad T30 Notebook
Battery won't charge
trying seeing the status of it in the bios! that usually tells you if the battery is faulty
it might make you caliibrate the battery to!
or it might not see it all which means its bad!
Feb 27, 2009 | IBM ThinkPad T30 2366 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
T30 2366 8GA After removing AC Adaptor battery icon shows Charging and working on AC
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
May 13, 2008 | IBM ThinkPad T30 2366 Notebook
T30 won't turn on
It might have some statical lockup
Here is the steps that you may try
Disconnect the AC adaptor, take the battery out, press the power button and hold about 7 second. Connect the AC adaptor and turn the unit on. If issue persists please post for further diagnostic.
Good Luck
Jan 27, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 no power
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
Aug 02, 2007 | IBM ThinkPad T30 2366 Notebook
I can't get my IBM T30 laptop to boot up at all
It may have a faulty motherboard or it is stuck in hibernation. To take it from hibernation you need to licate the CMOS battery, know this is where the problem starts. The battery (Small disc shaped, probably covered with tape.) could be underneath the notebook. If you turn it over there should be compartments where the memory harddrive etc reside, it could be in those places or even under the keyboard. If you are not too sure as you have to be very carefull, take it to a qualified repairer.
Jan 23, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
140 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
