Question about Nokia N70 Cellular Phone
Very serious problem
Hi the problem is this that i m using nokia N70 n i m facing only this problem that when ever i makes calls its only connect for 1:09sec or maximum 2:00 min not more then that and i formatted it so many times but still it gives me the same problem and i m very much in tense and i called my cellular network and its not a issue of network and when i change my cell then i can talk for hour and more then that but with nokia N70 i couldnt make so many calls for long time and can talk for an hour pls provide me its solution and i will be very thankfull to you pls reply me soon as possible u can reply me on my email address which is vickycool_4@hotmail.com
  • Anonymous Apr 15, 2008
    how to put battery n70
    President:
  • 1,017 Answers
Re-formatting your phone too often is not recommended.
If you download, Nokia PC Suite v6.85.14.1 and update the phone software it will probably solve the problem. The processor on the Nokia N70 isn't very fast so when using applications, give it time to operate. If you decide to do an update, first check that there is one available for your phone. Start by going to Nokia of your country. This is the UK site:
http://europe.nokia.com/A4144905 For Nokia PC Suite.
http://europe.nokia.com/link?cid=PLAIN_TEXT_14905 For update.
READ ON:
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Posted on Mar 11, 2008
My nokia n70 has a connection error when calling, there is a message sending icon permanately up and it doesn't recieve or make calls/txts
Hello - let's try and help. The N70 did have a software problem about 2 yrs ago that can be fixed.
The problem will shut down the phone while making calls.
Try this link to download the update - http://www.nokia.co.uk/support/product-support/nokia-n70
I found that it worked on my N70 - and it's been fine ever since. -- Ray
Jan 17, 2011 | Nokia N70 Cellular Phone
During call auotomatic loud speaker ;gallery ;444 dialing and finally call ended problem
go into your phone and delete what you downloaded just before your phone started this. more than likely you either have a virus or some program installed that is affecting your phone and making it do thing.
if you cannot get past this then you may need to reinstall your software.
Jun 02, 2009 | Nokia N70 Cellular Phone
Call from pc with use of my nokia n70
Hello there! thanks for using Fixya.com!
Unfortunately, we cannot use that feature especially as I know with Nokia N70 phone. You can only use bluetooth devices head sets or other supported devices via bluetooth. However, you may use your mobile as a modem and access thru GPRS and you may browse directly from your pc, just connect your phone with USB cable to your pc.
Here some details of the specifications, Here is the detail for this user guide manual: Nokia N70 Help Tutorial Useful shortcuts Clock Clock settings World clock Volume and loudspeaker control File manager View memory consumption Memory low—free memory Memory card tool Format a memory card Make calls Voice calls Make a conference call Speed dial a phone number Voice dialing Video calls Video sharing Video sharing requirements Settings Share live video and video clips Accept an invitation Answer or reject a call Answer or reject a video call Call waiting (network service) Options during a voice call Options during a video call Log Recent calls Call duration Packet data Monitor all communication events Personalise your device Profiles—set tones Offline profile Transfer content from another device Change the look of your device Active standby mode Contacts (Phonebook) Save names and numbers Default numbers and addresses Copy contacts SIM directory and other SIM services Add ringing tones for contacts
for more info, check this site http://www.ebookmanual.net/nokia-n70-user-guide.html
Feb 15, 2009 | Nokia N70 Cellular Phone
How to connect N70 to Video Call
hi
you have to activate the service from the company.
i hope this will work
Jan 03, 2009 | Nokia N70 Cellular Phone
Connection error
Connection error usually is because you set some restriction to make or receiv a call. However, this setting can also be done by the network provider.
And since you said you got no signal, means that your SIM card can not finish registering to the network, which normally means that your network provider is blocking your card. Same thing happen to pre-paid card which no longer in active period and already pass grace period.
I suggest you call the network provider, or come to their support center for solution.
Dec 14, 2008 | Nokia N70 Cellular Phone
Nokia n70
hi
you have to call the call centre service that you are using ask to the agent to send you the internet setting after that he will send you by sms save the setting as defult then open web
thanks
your friend from fixya!
Oct 25, 2008 | Nokia N70 Cellular Phone
Nokia N70
Go to Setting-Network-Operator Selection. Keep it Automatic
Go to Setting-Call-Send my caller ID. Keep it Set by network
& check your line in use. Keep it in Line 1
Jul 06, 2008 | Nokia N70 Cellular Phone
N70 comes on with whie screen and hangs
a lot tobe done in that problem of your... but i can give you one of the best... place yur unit in table so you can be cmfortable...the press all the keys in same time these keys are key *,key3,the call,and power on switch... much better if you had buddy beside you..to hold the unit... press them in same time or together, dont release it until you dont see a word formatting... wait until it finsih and the unit will be restarted by itself... enjoy
Nov 14, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
