DVD/CD rom not working
DVD/CD rom drive is not working. snapsys says it has been removed, how do I reinstall it.
  • 1 more comment
  • Anonymous Jul 17, 2008
    how do I dessemble the defective DVD CD-Rom from the PC?
  • breanne18 Aug 09, 2008
    my dvd/cd-rom is not working.. it said " the driver must be damaged or missing"
  • sunnybun Dec 27, 2008
    cd rom won`t play cds I get "Code 39" error message "or device may be corrupted" . My desktop in new and it did install my printer software?!
Cd and dvd is not working
Posted on Nov 09, 2008
I mean boss. d hardware. how to repair
Posted on Oct 23, 2008
    Sergeant:
    Champion:
  • 277 Answers
Configure device manager and remove auknown device driver, then restart the computer....
Posted on Mar 11, 2008
  • 47 Answers
Check your pins, or turn off your pc then unplug dvd/cd then plug it again then turn on your pc
    Master:
  • 518 Answers
Try rebooting the PC. If that doesn't work, you'll need to check BIOS to see what the settings are. Also check the cables to the drive, especially if anyone has been inside. Other than that, I suppose it could be a bad drive.
Geno
DVD FUNCTION WON'T WORK, what should i do?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Nov 11, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
My dvd rom not showing in nero programme
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 24, 2011 | LG GDR-8164B 16x DVD-ROM Drive -...
Cd rom driver
in most cases your CD-Rom drive won't need any external driver, because they are embedded in the OS. In case you are experiencing problem with your optical drive, just try to remove and then reinstall it from windows' hardware managment software.
Hope it helped,
Franz
Mar 02, 2011 | Computers & Internet
My CD Drive is no longer working it says code 39. I also tried my external DVD drive it says code 39 as well. How do I fix this?
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 21, 2010 | Compaq (120192-B21) CD-ROM Drive
My DVD/CD-ROM drives stop working. On the device manager itb says, Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Hi friend,
Firstly you update the DVD/CD-ROM drives form device manager and restart the system,if nothing happning in that condition you need to reinstall the DVD/CD-ROM drives through CD or net.
Thanks,
Feb 25, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Deleted/Corrupted CD-Rom driver
Go to the CD drive manufacturers website. Download the latest driver for you model # from the support section. After downloading install. Hopefully that will fix your problem. Please remember to rate my answer. Thanks.
Feb 07, 2009 | Intel Motherboard
! on my LG GCC4522B CD-RW/DVD-ROM
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Nov 21, 2008 | Computers & Internet
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
DVD works but not regular CD ROM
try frimware update for it from site ok pioneer.com ok
Feb 07, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Computers & Internet Logo
254 people viewed this question
Alun Cox
David Payne
David Payne
