Question about Proscan PSVR73 VHS VCR
Proscan vcr plus gold stuck in lock
Cannot get out of lock position to record
  • gramma2 Mar 11, 2008
    cant get the tape out to find out
  • Anonymous Mar 21, 2009
    proscan locked lost remote how can i fix this
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Posted on Apr 05, 2008
  • Victor Fernandez
    Victor Fernandez Oct 29, 2013
    l did what you said and is work,thank you very,very much
    New Friend:
None of the solutions worked for me! Any other suggestions?
I need help unlocking the vcr, so we can rewind, play, forward a tape. The vcr is Panasonic pv-4661
Posted on Jan 25, 2014
Per manual: PRO-TECT PLUS TM LOCKING To disable the usage of the VCR, or to protect your timer recordings, you can lock the VCR so that the buttons on the VCR or remote won't work. To Lock: Pressand hold either the remote control's ON-OFF, VCR1 or VCR2 button (whichever controls your VCR). LOCK appears in the display when the feature is activated. LOCK appears if you attempt to turn on the VCR while the feature is on. To unlock the feature and turn on the VCR: Pressand hold either the remote's ON-OFF, VCR1, or VCR2 button (whichever VCR button your VCR is set to respond to). Manual located at http://disruptit.com/manualgateway.cfm?pdfwanting=5230&username=anon&AV=123345&I=24.90.178.87
Posted on Jun 07, 2009
  • Victor Fernandez
    l did that and work perfect, thank you very much
    Master:
  • 518 Answers
Is the anti-record plastic tab still on the tape cassette?
Geno
Posted on Mar 11, 2008
How do I stop my ProScan VCR from recording?
I need more information, but if you find you are accidentally recording over tapes that you never want to record over, break off the record tab on the cassette itself.
If you do ever need to record over a tape with the record tab broken off, simply place tape over the tab hole.
If you don't mind voiding the warranty, you can install a record safety switch either in series or parallel (depending on the sensor type) with the record tab sensor inside the VCR, or in series with the record button itself.
Hide the switch in the back of the unit so nobody finds it.
Feb 24, 2011 | Proscan Televison & Video
What is the vcr plus code? where do I find it?
i would like to obtain codes to record programs on a vcr that needs vcr plus codes
Mar 06, 2010 | JVC DR-MV1SU DVD Recorder/VCR
Doesn't give me the option to change the channel when timer recording
If you are recording something on the VCR, it won't let you change the channel. If not, you need to make sure the RC is set to the vcr in question (mine has VCR1 and VCR2)
You can set it up the way I've done for years...put cable line into VCR first, the VCR to TV..you then can watch and record 2 separate channels.
May 09, 2009 | Proscan PSVR73 VHS VCR
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Proscan vcr
you must have the vcr on child lock.should be somewhere on your remote to switch off or go through menu
Dec 14, 2007 | Proscan PSVR72 VHS VCR
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
My vcr lcd reads LOCK now and I can't access any menu functions
My Proscan PSVR74 turns on, says "Hello" and immediately goes to Stop and turns itself off. Is there any hope for this machine?
Joe
May 08, 2007 | Proscan PSVR73 VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Cant play tape
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 28, 2006 | Proscan PSVR73 VHS VCR
Televison & Video Logo
600 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
