Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Problems starting up a PC can be tricky to fix, since Windows hasn't had a chance to load its arsenal of troubleshooting tools. Some people simply give up and reinstall Windows.
Startup Repair can prevent a time-consuming reinstallation by diagnosing and repairing problems that prevent Windows from starting.
Startup Repair is designed to start automatically if Windows detects a startup problem. For more information about using Startup Repair, and what to do if it doesn't start automatically
here is my solution... when you boot your window when you're middle in dos loading press F8 and select boot in safe mode... then when you are in windows click start --> all programs ---> accessories---> sytem tools ---> system restore... hope you back up your windows.... try to restore your window in earlier time...
HOPE IT HELPS AND GOD BLESS
