E70 error on Model LTF2940FE1 Front loading washer
Model LTF2940FE1 constantly giving E70 errors. Suggested trouble shooting followed - cold water hose is connected to correct line and fully functional
  • Anonymous May 04, 2008
    I just want know .what is E70 on my washer .can you tell me .what is wrong
  • Anonymous Apr 14, 2009
    E59
    President:
  • Washing Mach... Master
  • 2,651 Answers
Good to see you cked that , 1 question though are you by chance using stainless hoses made by company FLOODSAFE. if so theres your problem theres a shut off inside the hose itself that is malfunfuctioning, replace with regular s/s hose and all will be good. if your not usinf a floodsafe hose hten lets go to the next hting- when oyu first start machine, cold water flows in before cycle even starts, can you hear it coming in??? at least trying perhaps a light humm with no water? water vavle is located under main top you can remove the top and check for voltage when trying to fill
Posted on Mar 10, 2008
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
Kenmore eco cycle front load washer. error E70 displays and stops washer. What does E70 mean?
You should check the model number of the washer. If the model number starts 417, then the washer was made by Frigidaire. In that case, the E70 error indicates that cold water is not being detected at the washer inlet sensor.
In some cases, this could be due to connecting the hot water line to the cold water inlet (and the cold water to the hot water inlet). Make sure that the cold water shut-off valve is open. Try swapping the water hoses (close the shut-off valves first). Try new hoses; some anti-flood hoses will restrict the water flow if they detect damage. Thus you won't have sufficient water coming into the washer. (You can check this yourself. Turn off the shut-off valves. Disconnect the hoses from the washer and put the ends into a bucket. Then open the shut-off valves and check the water flow.) While you have the hoses off, check for debris in the inlet filters.
If the hoses are fine, you probably have a problem with the washer's inlet valve or the reed switch that measures incoming water. The inlet valve should be replaced if you find that only hot water enters the washer.
I hope this helps. Please add a comment with the model number of your washer for more information. It will be on the inside of the door opening (probably at the top).
Sep 30, 2013 | Maytag EPIC MFW9700S Front Load Washer
Error code #E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.Hope this helps... Please post back for more information.
Daniel
Nov 16, 2010 | Kenmore 43142 Front Load Washer
It is stopping in the cycle and reading E70 on the screen.
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.
Hope this solution will fix your problem for sure.
Thank You !!
Jul 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
I am getting an error E70 have a frigidair Affinity Washer
Thank You !!
Jun 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does E70 means? My washing machine have this after it started for a few seconds.
hi,
Thank You !!
May 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
E70 error code
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.... Hope this solution will fix your problem for sure.
Mar 30, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E70 on my Frigidaire front loading washer model LTF2940FEO
The hot and cold water hoses were connected wrong to the washer.
Dec 22, 2009 | Frigidaire Washing Machines
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
594 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
