press the user tool counter key, press system setting, key operator tools, set key operator codes to offpress the user tool counter key, press system setting, key operator tools, set key operator codes to off
You can't post conmments that contain an email address.
Try using www.unlockbiosrecovery.com they supply bios master passwords and hard drive master passwords for most laptops. They charge $20 for bios master passwords and guarantee it to work or your money back.
Hi, you can turn off the key code management by going into User Tools. Press the User Tools/Counter button, then go to System Settings and then Admin Tools. There should be an option on the screen (you may have to scroll down) for key counter management -- turn this option off.
When you exit out of User Tools, you should be able to see the Copy screen just like you normally would, without having to enter a key code.
If the message on screen is asking you for a User Code rather than a key code or key counter, that option can also be disabled in User Tools. Go back into the Admin Tools and look for an option called User Authentication Management, or something similar, and either disable it completely or disable it for copying.
the problem is with the toner density sensor.a quick fix would be to replace the photoconductor unit.thereafter you need to do the developer initialization adjustment.
Restart the computer pressing the "F8" key. When a list comes up choose "Start in safe mode". Log in as the administrator. Go to the control panel and choose "User Accounts" then click your username and hit change password.
