Question about Orion1934 19" TV
Screen there is a black box in the middle of my screen. I initially thought it was the cable box, but it is present on every channel. Please help.
  • 129 Answers
Good day.
Check on you set up/menu and try to look if you have set up the caption mode.
chris
Posted on Mar 11, 2008
Our Panasonic Viera TC-32LX700 displays "Channel not found". We have unplugged it and gone through the initial set up all over again. It is connected to am antenna, not cable. After the display, the screen...
Try relocating the location of your antenna or changing the direction it is pointed. Once this is changed, select PROGRAM CHANNEL from the SETUP menu and set ANT IN to Antenna before selecting Auto to start the programming process.
Oct 19, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have a TV with a DVD player combo, #NS-13CTV. On my local channels I get a black box right in the middle of the screen. On the other cable channels it does not appear. I can't get it off. This annoys...
hummmmm
can u set your dvd pleyr in your av mode
if not did then u cant see any channels so put your dvd plyer pin in to av mode its bhind tv or front side there is 2 socet come one for video other for audio
so & start av channel in your tv
try
Mar 29, 2008 | Televison & Video
Black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Jul 10, 2009 | JVC AV-36150 36" TV
Black box in middle of screen on 2 channels 42LG70 plasma model T
It sounds like your tv is in text mode for the captions. Try going into the menu, and go into captions, and set it to off. That should solve the problem. If not, do U have a cable box? If U do, try the same approach with the cable box B4 concluding it's something wrong with the tv.
May 01, 2009 | LG 42PB4D 42 in. Plasma HDTV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Thick Black Line Down Middle of TV
does this only occur with one input and/or does it occur when using HDMI/component cables.
if so, try getting a new HDMI cable. I have the same problem with PS3...and im about to order a new HDMI cable.
Sep 30, 2008 | Panasonic PT-52LCX65 44" HDTV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
When a black box appears on the screen it means that your closed captions are on and set to TEXT. When the closed captions are set to CC1, it puts the words on the screen and when set to TEXT it puts a black box in the center of the screen. Go into the set's menu, navigate to the closed captions page and set the captions to OFF.
Aug 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Orion1934 19" TV Logo
62 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
