Question about Microwave Ovens
Microwave I am trying to replace the handle on my microwave's door- Panasonic, model # NNS789WA. How do I go about disassembling the door. Thanks.
    Genius:
  • 3,587 Answers
Ok..let me get you that assembly drawing..one moment please..
Posted on Mar 10, 2008
  • Patrick Michaels
    Patrick Michaels Mar 10, 2008
    unplug the unit, of course
    there are four or six screws along the bottom of the door..remove these...the door should separate like a clamshell..
    be mindful of the electronics..if you wish, you can remove the whole door, but that's a much longer process.
    the door handle is held by two screws accessible from inside..using a long handled screwdriver, undo those, and then replace the handle..reverse above.
    Just be careful NOT to pry the door too wide, as it's not necessary.
    if you have a magnetic screwdriver, this works a lot simpler.
  • Patrick Michaels
    here's a link to where you can purchase one authorized manual
Model E130BM55HSC. How can I replace lower door handle bracket?
Hello Teresa, thank you for your inquiry!
I understand that you need assistance replacing a component on your Electrolux microwave. In order to replace the bracket you would need to disassemble the door. You should seek help from a professional technician for proper assistance with the disassembly. This will help you avoid any personal harm of improper disassembly of the microwave. Best of luck! -Matt
Mar 09, 2016 | Electrolux Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Fridigaire over the stove microwave. the handle is broken. We can order a new handle but don't know how to install it. Can you help? thanks, Linda C. e mail ...
You must take the door out by removing a screw then lifting the door off the hinge pin then the door must be laid on it's front and, completely
disassembled to replace the door handle.
Aug 13, 2010 | Frigidaire Microwave Ovens
GE Microwave model JVM1650CH01. Trying to replace door handle." I have removed panel on inside of door and removed 2 screws to handle. It appears that there are screws holding the outside cover of door...
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
May 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
Jenn air microwave oven door handle
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Mar 24, 2008 | Microwave Ovens
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Microwave door handle
First, never remove the door. You will disturb the alignment which holds in the microwaves. Generally, the door can be disassembled by removing the screws on the cavity side of the door. Once inside, then you should be able to replace the handle. Often the screws are of the torx variety...also call star.
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave oven
You'll need a new door handle.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 23, 2007 | Jenn-Air M439 Microwave Oven
Disassembling door to replace plastic outer panel - how to remove handle
You can visit http://www3.sears.com/ (the 3 is correct) You will need to enter your full model number (not just 61709) and you can see expolded view diagrams which can be very helpful. Chances are the panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices.
Dec 20, 2006 | Kenmore 61709 Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
