Question about Vacuums
Eureka canister vacuum model 6865- cleaning
Eureka canister vacuum model 6865 that i use daily for my cleaning business in a high dust office. How do I clean it. I can't find my manual and need it tomorrow for work. the service guy wants it for a week.
If you can point me in the right direction of where i can download that owners manual would be great to.
Thanks
  • Anonymous Mar 13, 2014
    canister will not clip in
  • Anonymous Mar 31, 2014
    Do you oil a eureka 1514 canister princess and where. What other maintenance do I need to do?
    Genius:
  • 1,665 Answers
    President:
  • 1,673 Answers
70227 is the part number for the owner manual, but you would have to have it order it. You can call 1-800-282-2886, this is Eureka's customer service, they don't have it in their data base, but maybe they can find something for you.
Posted on Mar 11, 2008
What should I check to trouble shoot a Eureka 6865 smart vac making very loud whirring noise? Filter and bag are clean. Hose is unblocked.
Hi, it's Jim from Crucial Vacuum!
I'd say at this point if you've checked your bag, filter and hoses it may be time to check your brush roll and belt. These two fast moving parts, when loose, damaged or just in need of replacement may occasionally give off an odd noise.
Turn the power wand over to expose the base plate that covers the brush roller. The power wand can get dirty and collect debris in the brush roller over time. The grinding noise may be something stuck in the brush roller, causing it to hit the edges when the vacuum is operating. Removing obstructions and cleaning dirt and debris collected over time should allow the vacuum to operate quieter. Unscrew the base plate cover with a Phillips head screwdriver. Lift out the brush roller and belt. Cut away any obstructions, such as string, hair or rubber bands, from the brush roller. Wipe the brush roller and belt with a damp rag to remove any dirt and allow them to air-dry. Wipe down the brush roller housing and inside the base plate with the damp rag. Any noticeable difference now once it's dried and turned on?
Should you need any replacement parts for your Eureka in the future please feel free to order direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Check out our lineup of Eureka replacement parts at the below link.
http://www.crucialvacuum.com/catalogsearch/result/?cat=27&q=Eureka+6865
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Oct 19, 2014 | Vacuums
Where is the reset button on my eureka canister vac
with out knowing the model # i can't say for sure. however most of the eureka canister vacuum's ive worked on do not have a reset button. If its not working is probably the cord or switch that has gone bad. hope this helps
Jan 14, 2013 | Eureka Vacuums
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
HI, need bags and belt for eureka smart vac 6865
the chaepest places are target, wal-mart,k-mart,etc....
Oct 19, 2009 | Eureka Smartvac 6865E Vacuum
Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Oct 16, 2009 | Vacuums
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
High pitch whirr
when you remove the canister to empty it there is a filter on the bottom that can be removed and cleaned or replaced check to see if there is also one on the top.
Apr 14, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka bagless uno 12 amp ( green)
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
Oct 03, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Eureka optima
The filter probably needs a darn good clean. If it is clean, wipe the inside of the canister with a clean cloth to get rid of static.
Oct 13, 2007 | Eureka 431A Optima Bagless Upright Vacuum
Vacuums Logo
349 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
