Question about Sony Cyber-Shot DSC-P100 Digital Camera
Power On Button
Since downloading some photos to PC my camera could not be switched off. When I pressed the power button it went off for a second and then came back on. Battery eventually discharged. Now cannot recharge as camera needs to be turned off. When charger is plugged in camera just comes on again and stays on. I have taken out battery, reset camera. I always use 'safely remove hardware' when disconnecting. Faulty power button or camera jammed electronically ? Any ideas ? If I can't fix it myself, I'll just get a new one (not Sony). Advice would be appreciated.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
I hve transfered all the photos from my Hero 16 MG disk to my PC. it is still not allowing me to take new photos and videos just indicating "Full"Unclear how to erase my disk. Any assistance you could
Here are the steps to reformat your SD card with your HERO3 camera:
  1. Power ON your camera with the SD card inserted.
  2. Press the front (Power) button repeatedly until you see the wrench icon on the camera's screen.
  3. Press the top (Shutter) button one time.
  4. Press the Power button repeatedly until you see a trashcan icon.
  5. Press the Shutter button one time to select the trashcan icon.
  6. Press the Power button until "ALL/Format" is highlighted.
  7. Press the Shutter button one time to select "ALL/Format".
  8. Press the Power button until "Yes" is highlighted.
  9. Press the Shutter button one time to select "Yes". Your camera's LED and the trashcan icon will blink to indicate that your SD card is being reformatted.
Once they stop blinking, power OFF/ON your camera, and your file counter should show 00.
Important - Take a picture. This confirms that your SD card is successfully reformatted.
Sep 19, 2014 | GoPro HERO3 White Edition Action Camera
My samsung s630 camera takes more time in processing after capturing photo
You can follow these steps below.
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
*******2nd solution
It may require a firmware upgrade. That will involve going to the Samsung website, following links to support/downloads and checking to see if there's an update for your camera.
Apr 30, 2011 | Samsung Digimax S630 Digital Camera
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
My samsung ES55 camera wont switch on and its fully charged.
I have a Pink Samsung ES55 and The first time I pressed the power button it turned on. However when i went to turn it on the second time by the power button it didnt work. I tried to charge it again and it didn't work by this time I thought I'd broken it or something but then i pressed the bottom play button in a square/box twice and it came on I was so seriously relived. :) hope I helped
Feb 01, 2010 | Cameras
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
the PLAY MODE button once to switch to Play mode and press it again to switch
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
play mode. Press the play mode button again and the camera will be turned off.
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
2. The last image stored on the memory is
displayed on the LCD monitor.
● Playing back a still image
1. Select the PLAY mode by pressing the
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
How to take pictures with this camera -- have no instructions -- new to this -- camera was given to me -- replaced batteries -- 20 shows in view finder -- push button -- nothing happens
1. Turn the camera off by sliding the ON/OFF switch (to the right of the LCD) down to the OFF position. 2. Reinsert the batteries, making sure their polarity alternates, with the battery closest to the hinge of the battery cover pointing down into the camera and the other one pointing up. 3. Turn the camera ON. 4. Press the button on the back of the camera to select the mode. If you do nothing, then the camera is in the Hi-resolution mode. The display will momentarily switch to 20 to indicate that 20 photos are available. When you take a photo, the number will decrease. 5. Press the button on the top of the camera body to take a photo. The camera will beep when you do. 6. IMPORTANT: do not switch off the camera until you download your photos to your computer. 7. Plug in the camera to your computer with its USB cable. This will power the camera when the computer is powered and save your batteries until you can download them to you computer. 7. Install your software and follow the directions (you need to unplug your camera before you start the installation). Once you load the CD, the installation wizard should begin. If it doesn't, then your computer is not recognizing the software. Note: this software does not work on Apple OSX operating system (on my Mac), and I'm having trouble making it work on Windows XP (on my PC).
Jul 14, 2009 | Cool-Icam 2U Digital Camera
Deleting photos
  • Set Mode Dial to Play and power up the camera.
  • Press < / > on control button to select desired picture to delete.
  • Press Menu button and press < / > to select Delete option and press Center of control button.
  • Confirm OK by pressing ^ button and picture will be deleted.
You can download user manual of DSC-P71 from Sony Support. It has better details on how to delete file.
Nov 18, 2008 | Sony Cyber-Shot DSC-P71 Digital Camera
Upload fotos
Here's how...
  • Starting PC mode
If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
In this mode, you can download stored images to your PC through the USB cable.
The LCD monitor on the camera is always turned off in PC mode.
  • Connecting the camera to a PC
1. In any mode, except Voice Recording mode, press the Menu button.
2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
5. Press the menu button twice and the menu will disappear.
6. Connect the PC to the camera with the USB cable.
  • Downloading stored images
You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
3. Select an image and press the right mouse button.
4. A pop-up menu will open.
Click the 'Cut' or 'Copy' menu.
- 'Cut' : cuts (i.e. moves) a selected file.
- 'Copy' : copies files.
5. Click a folder where you want to store the file on your PC.
Don't forget to rate this solution once you've tried it !
Good Luck.
May 20, 2008 | Samsung NV3 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Taking still photoes with the memory stick.
1. Set the mode switch to MEMORY STICK. 2. Set the power switch to CAMERA. 3. Press the PHOTO button and hold it. **If you do not wish to keep the still photo, wait 2 seconds until the picture releases. 4. To keep the image, pess the PHOTO button once again within 2 seconds after releasing the button. The still image is recorded to the Memory Stick. **Audio cannot be recorded onto the Memory Stick.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Cyber-Shot DSC-P100 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
