Question about Fedders AEY08F2FCOM Wall/Window Air Conditioner
Compressor runs even when turned off
No matter what I set it on the compressor never goes off even if I have it set to fan only or have it set of 88 degrees.. It will ice up behind the filter so I unplug it. When I plug it in the next day its the same thing. The compressor comes on even with the unit turned off or put on the highest temp or fan only does not matter.. Its the AEY08F2F
  • Anonymous Apr 13, 2008
    I'm having the exact same problem. I've tried the reset swtich and even tried just unplugging the unit to reset it. No luck.
  • 30 Answers
You could have a relay stuck closed, so every time the power is on it feeds electricity to the compressor.
Posted on Mar 11, 2008
The A/C will not turn off on my 2006 Kia Sedona EX. Air blows cold, but no matter where you set the control knobs for A/C system or fan controls the A/C stays on. Even with knob in the OFF position.
Looking under the hood in engine compartment with engine running A/C off , the compressor is engaged ? If so , the A/C compressor clutch relay is stuck closed energizing the compressor clutch all the time . Now if your talking about the blower inside the car running all the time , air blowing out of the vents . The A/C isn't engaged . Could be blower motor relay stuck or the control module is bad .
Jun 21, 2016 | 2006 Kia Sedona
1995 Oldsmobile 88 Royale - AC Issues
So the ac is not working. Is the compressor running when you have the control set for ac ?
Jun 27, 2013 | Oldsmobile Eighty Cars & Trucks
Compressor fan spins at low speed
The contactor is a power passing device.Even though it is closing, it is possible its not passing the required voltage to operate other power consuming components such as the compressor and fan.Being exposed to the elements it's common for the contactor to go bad.They are fairly inexpensive and I would start by replacing it first before accusing any other component.
May 31, 2012 | Heating & Cooling
Compressor will not stay on no matter the temp. setting. After running a couple of minutes the unit emits a scraping or buzzing noise and compressor goes off.
Sounds like you lost one of your fans if air is circulating in the room its the condenser fan. Thats what blows across the condenser coil to the outside. It may just be a capacitor thats what helps the fan get started but usually if the fan is popping capacitors there is something wrong with the fan but at the same time capacitors do just go bad. hope this helps let me know.
Jul 23, 2011 | Frigidaire FAH126S2T Thru-Wall/Window Air...
The fan on my outsie unit of my grand air heat pump won't turn on. The compressor hums. If I manually turn the fan it will run but very slowly.
Your description is possibly a bit vauge for the problem it could be, but starting from the compressor, question is "can you hear the compressor running"? If you can then switch off quickly and check the cooling fan capacitor. almost certainly it has popped.If it has, and even with a new capacitor it wont start, then a complete condensing fan unit is required.If the compressor isnt running, then one of a few things could be the problem. A- The voltage getting to the compressor or the cap, is not correct which points to a problem with the board. B- If the compressor is jambed,(siezed),then it is bringing the voltage down to the point where even the fan cant run. Need to check those points to determine the next course of action.
Aug 28, 2010 | Goodman CLQ36AR49 Air Conditioner
I just bought a Danby Dehumidifier model: DDR6009REE The fan runs constantly even when the humidity setting is reached and the compressor is off. has anyone patched the power for the fan by putting...
All new generation dehumidifiers are designed to have the fans run all the time and the compressor comes on when the relitive humidity rises above the setting that you have chosen. I spoke with the company and asked them why this is so, and they told me that it is more energy efficient to have the machine on all the time so that when the compressor kicks in there is a small draw on electricity.
Apparently when the old dehumidifiers came on it was the compressor that turned on immediately, and the fan, and this caused a very high current draw. The new design has the fan on all the time and this helps to circulate the air evenly around the area being dehumidified - thus more efficient overall coverage.
I understood their explanation, but still do not like this new method of operation.
Jun 26, 2010 | Danby DDR6009REE Dehumidifier
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore 580.51650000 dehumidifier: compressor cycles on and off as it should based on humidity setting but the fan is always running, even with the compressor off. Checked humid sensor. Any other...
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
Aug 21, 2009 | Dehumidifiers
Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
May 03, 2009 | Refrigerators
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Fedders AEY08F2FCOM Wall/Window Air Conditioner Logo
145 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
