Question about Sanyo PLC XU30 Multimedia Projector
Plc-xu30 The screen goes to a outer angle from top to bottom how do i fix this
Cyber Greg is right!! Just Keystone that baby!!
Posted on Jun 29, 2009
This is called "keystone adjustment". If you still have the owner's manual, it will describe how to do it. If you don't have the book, look on the button console on the projector, or on the remote for an icon that looks like a rectangle that is either narrow at the top or narrow at the bottom and press it. That will get you in the control. If there's no button, you will probably find it on the set up menu. It's pretty easy to do the adjustment, one way makes the image narrower at the top, the other makes it narrower at the bottom. Some older projectors just have a **** on the unit that changes the angle of one of the mirrors inside to accomplish the same thing. The reason for this adjustment is to compensate for the distortion of the image caused by a projector mounted near the ceiling and pointing down at the screen, or sitting near the floor and point up at the screen.
Posted on Mar 11, 2008
Plc-xu30 wont power up
Switching of Projector within few seconds ??!!
This problem is common when Projector lamp is not replaced with that of the same band & model but one can fool the projector lamp as it powered with logic switching ...0 V or 5 V set by its company ...
Go through following Web :
http://www.diy-community.de/forumdisplay.php?f=60
http://www.allinbox.com/modding.htm
http://www.dity.nl/forum/lampen/442-...qi-lampen.html
http://recklessphilosophers.com/2008...ad-of-300.aspx
Jun 20, 2012 | Sanyo PLC XU33 Multimedia Projector
I cannot get my remote to work with my Sanyo PLC-XE30 projector
I would first try changing the batteries in the remote and verifying that batteries are in the right direction (+ and - terminals line up).
Once that is done, try pointing the remote right at the infrared sensor at the front of the projector...the black plastic circle on the front of the projector.
Mar 04, 2011 | Sanyo PLC XU30 Multimedia Projector
My projector only plays black and white when connected through the tv
Depending on the connection type it's either the cable isn't properly inserted at one end or the other or it's expecting rgb and it's geting a composite feed.
Jun 12, 2010 | Sanyo PLC XU30 Multimedia Projector
I need a service manual for a Sanyo PLC-XU30
Go to Sanya website .click on support ,put in you rmodel# and they will let you download it free.
Jan 23, 2010 | Sanyo PLC XU30 Multimedia Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off...
on my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
Jul 28, 2009 | Sanyo PLC-XU30 LCD Projector
How do i change the bulb in a sanyo pro xtrax multiverse plc-xu30 prodjector
remove the screw on the door on the bottom of the projector for the lamp and pull out the old bulb and replace
Apr 16, 2009 | Sanyo PLC XU30 Multimedia Projector
Ghosting image
Hi there
I'll bet you any money that the problem is cable related.
We often get this problem and by swopping the cables we normally get the problem solved.
Hope this is of help
Mar 26, 2008 | Sanyo PLC XU30 Multimedia Projector
Sanyo PLC XU30 Multimedia Projector Logo
197 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
