Question about Apple iPod nano
I connect Ipod to computer it will not sync
I plugged my Nano into the computer and it just sits there, does not charge nothing, the Nano works just fine... I think it might be something with the firewire. But the computer doesn't even recognize that its plugged in...
  • rachelle
    rachelle Mar 12, 2008
    i tried following the reset steps but this did not work. is there anything else i can do?
  • 405 Answers
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
http://www.pchelpforanyone.blogspot.com/
Posted on Mar 11, 2008
4 Suggested Answers
  • 57 Answers
SOURCE: Can I use Firewire to charge?
Unfortunately, the iPod nano only ships with a USB 2.0 cable, which alienates many Mac users who only have USB 1.1 and Firewire ports. Although Apple offers no official support, you can both charge and sync your iPod nano, albeit slowly, using USB 1.1. Or, you can charge your iPod nano, but not sync, using Firewire.
Posted on Sep 29, 2005
  • 57 Answers
  • 57 Answers
Posted on Oct 02, 2005
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
Aug 05, 2013 | Apple A1199 ipod nano
Want to just charge my ipod nano using my computer but it's synced with another computers library and don't wan lose my songs..it already erased them once even when i chose not to syc...now every time i...
Connect it to the computer.
Open iTunes and select the Nano.
Uncheck Open iTunes when connecting this iPod.
Don't have iTunes open when the iPod is connected.
Sep 11, 2010 | Apple iPod nano 5th Generation
Ipod nano 4G silver not syncing
Well if you bought it off of ebay or some other internet site you might have bought a clone ipod that only syncs with windows media player, but if you bought it from a certified Apple reseller than I dont think I know. goodluck !
Feb 28, 2009 | Apple iPod nano
install the version 7.7.20.14 it may work
Jan 09, 2009 | Apple iPod nano
The i pod is not showing that it is charging
Since it has been sitting for so long, try doing this: Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
Dec 30, 2008 | Apple iPod nano
Apple screen
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge normally, just enough so that it can come on and sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, wait few minutes, charging. It should work after letting it sit plugged up to the computer.
Oct 17, 2008 | Apple iPod nano
2nd gen nano not synching
Put it on autosync or tick all the box's songs you want and manually press sync button on the right bottom corner.
Make sure ur ipod is plugged in
Aug 20, 2008 | Apple iPod nano
Just a quick question, Is the driver installed for your USB?
Jun 01, 2008 | Apple Mini IPod
I cant sync or charge my 1st gen ipod nano
i had this problem a little bit ago... the problem is that the ipod is not recognizing any firewire activity which is a problem that the apple store with fix and give you a new referbished ipod
Aug 24, 2007 | Apple iPod nano
Apple iPod nano Logo
414 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
