Question about Canon Pixma iP6000D InkJet Photo Printer
Canon ip6000d error like none other..
Here's a head scratcher for all you printer techie's. I've been servicing these printers for a while now and this is the first time I have received a message that says.."The appropriate printhead is not installed."
Now, I was basically in this machine to clean out the waste absorbers and the pump. Which I did. When I got it back together I put in the same printhead that came out of the machine. Yet, when attempting to do a print alignment I received the message above.
I also have no display showing anymore. Thought this was a contact issue, that I resolved, but still no display. Could the 2 be related?
I have taken the printhead carriage apart and all is connected and looks normal. I have checked all connections and everything seems to be fine.
Is there something I am missing here? Anyone have any information on this strange error?
At one point it did give me an error 5700. Here is the other strange thing...
The error above...The appropriate printhead not installed. Comes up on the computer screen, but guess what? No flashing, blinking lights to indicated that the print head needs replaced.
U scratchin yer head? cause I am. Any help would be greatly appreciated.
  • 1 more comment
  • marbleflat Mar 21, 2008
    I have the same error code problem of 6B00.  Does any one know what this is?  With ip3000, it was said that it is the squeeze problem, but not sure.
  • Leilani Ramos May 29, 2008
    error sign "print head not installed". I just changed the ink tanks suddenly this error message appear. what will i do. i've tried turning it off, unplugging it likewise, but the error still there
    print head not installed message after i've changed the ink tanks. what will i do it never disappear even i turn it off and unplugged it.
    Genius:
  • 3,587 Answers
Appropriate usually signifies that there's something amiss about the connection information either mechanically or electronically between the printer and the cartridge..I'd suggest you re load some drivers and see how that helps or does not?
Posted on Mar 10, 2008
User manual for my printer wich is a canon printer pixma ip6000d plus purchase 6 cartridges
Check this at:
http://www.retrevo.com/support/Canon-iP6000D-Printers-manual/id/259dj495/t/2/
Nov 08, 2011 | Canon Pixma iP6000D InkJet Photo Printer
My printer Canon PIXMA iP6000D stopped printing and ERROR 5200 appeared.
Error 5200 is print head temperature rise,you need to change the print head.The part number is QY6-0050.If a have been useful please give me a vote :)
Mar 11, 2011 | Canon Pixma iP6000D InkJet Photo Printer
WASTE INK ABSORBER FOR CANON
Hi there this not for your but it may do worth a try
I enter service menu like this:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
Feb 19, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Printing black pictures green
check all inks replace as required run test first check leads
Oct 03, 2009 | Canon Pixma iP6000D InkJet Photo Printer
How do i fix my canon pixma ip6000d when i switch on error code 5100 appears
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Sep 25, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Suddenly starting receiving "print head not installed" error
open your printer head and see it is burning change it and buy new
Jun 29, 2009 | Canon Pixma iP6000D InkJet Photo Printer
"The waste ink absorber is almost full." message on my computer
no it is the function of software some of wast ink is over the absorber pad reset your printer any canon service centre. first time off printer press resume button and then printer on wait three second then relaise this button
Jun 27, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Hi, just trying to solve a problem with Canon Pixma iP6000D printer. For some reason it does not print the black ink but all the other colours??? Any help? Tks Mark
make sure that there was still black ink on your the printer.
Clean the print head if you suspect that the nozzles might be clogged.
  • Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
May 01, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
646 people viewed this question
old marine
old marine
