Question about Lucent Cajun P333T Networking Switch
Cajun P333T doesn't accept input from serial
When I connect to the switch using the serial interface, I get the username prompt but nothing I type seems to register. I've tried both Hyperterminal and SecureCRT, with no luck. Am I doing something wrong? Do I have a wrong setting on my terminal app? I'm using VT100 emulation, 8n1 with no flow control.
    Novelist:
    Scholar:
  • 134 Answers
All info from juliankov appears good.. but thought I'd add a bit of stuff I found on a web site..
http://www.tek-tips.com/viewthread.cfm?qid=300461&page=2
Use a console cable with following minimum pinout (the flat gray one with the RJ45- D9 type converter currently shipping with new P33xx switches will suffice): DB9 Console Port
1 ----------- 6
2 ----------- 3
3 ----------- 2
4 ----------- 4
5 ----------- 5
6
7 ----------- 8
8 ----------- 7
9
Obviously the speed is set to 9600
maybe stop all sessions & try to re-establish a new one. The instruction manual warns u can only run one..
Posted on May 04, 2008
PLZ tell me avaya cajun p333t switch how to give console
Posted on Dec 28, 2009
    Problem Solver:
  • 13 Answers
Hi, it sounds like its not receiving anything from your console. your settings sounds correct for your serial comms etc.. if you can see the data coming in on the screen (ie user prompt). Check your serial cable to ensure you have actually wired it up correctly, perhaps the wire for Rx has fallen off / bad solder joint (at the network switch end), or could be the Tx end as well (at the computer end). check that all the pins look okay and aren't bent at the computer serial port, you could also try another serial port or another computer. I use Hyperterminal for many applications. You may also need to use a null modem serial cable (i dont know what you are using).
How to switch on poe function at switch port
Hi
Instructions
telnet to the IP address of the Cisco switch
Enter the telnet access password for the Cisco swict when requested, and then the "Enter" key.
Type "enable" at the command prompt, and then the "Enter" key.
Enter the Privileged Exec password when requested at the command prompt, and then the "Enter" key. Then enter "configuration terminal" at the command prompt, and then the "Enter" key.
Type "interface fastethernet0/1," replacing the "fastethernet0/1" with the name of an interface in which you wish to enable PoE, and then the "Enter" key. Then, while in interface configuration mode, type "power inline auto" and then the "Enter" key. Repeat this step for each interface in which PoE is required.
Type "end" at the command prompt and then the "Enter" key, copy running-config
Below is some commands to run, I don't have any power on the interface but this will show you if this is working...
SW1#sh power inline fastEthernet 0/1
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Run this command to see the interface is up.....
SW1# sh interface fastEthernet 0/1 ' in protocol
FastEthernet0/1 is up, line protocol is up (connected)
SW1#sh cdp interface fastEthernet 0/1
Encapsulation ARPA
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
Thanks
Jul 31, 2014 | Cisco Catalyst Computers & Internet
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Tenda router input eror
It's not the username and password from your ISP. If you try to access your router and you have not changed anything, use the following values:
username = admin
password = admin
Once in the router interface, you will have to configure the router for your DSL-modem (I guess it's DSL since Windstream does not produce cable modems.)
Here fill in the username and password your ISP provided you with.
Let me know if you have any questions.
Nov 14, 2012 | TP-LINK Tenda W311R WirelessN Router AP...
How can i administrate a cajun p115g because it dosn´t have a console port?
open up internet exploer on any machine and type ip address into the url bar the default is usually 192.168.1.1 but yours maybe different to know your ip address open up your command prompt and type in ipconfig
to open your command prompt in windows xp click run from the start menu and type in cmd
if it is Vista then type cmd in the search and choose the first option
Oct 21, 2009 | Lucent Cajun P115G (108360850) Networking...
Need to know the command line commands for Avaya Cajun P333t switches
cajun switches have pretty similar command structure as cisco. use the ? mark for help.
Jun 03, 2009 | Lucent Cajun P333T Networking Switch
Password Recovery
The login you are using should have placed you in super-user mode. Are you connected directly to the switch with a serial console cable?
Jan 09, 2008 | Computers & Internet
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Nov 09, 2007 | Lucent Cajun P333T Networking Switch
Help me with a Cajun p333t
it is reseting because it dosent have a lot of branwith
Sep 13, 2007 | Lucent Cajun P333T Networking Switch
Save config
After changing all the necessary parameters using the CLI, use the write command to save your system configuration. If you receive any error messages, your configuration has not been saved. You must correct the errors and re-issue the write command. Notification of write errors is presented in a two column display: ? The left column contains the parameter values that you set in this session and need to be changed. ? The right column contains the parameter values currently saved in the Cajun P116. Wait 15 seconds for confirmation of the write process. Then exit Privileged level by typing exit at the prompt. For example, CajunP116-priv# exit. The cursor changes to CajunP116> to indicate that you are in Normal level. Verify that all the parameters were accurately saved by using the show all or show all list command. The Cajun P116 is now ready for cabling and operation. You may exit your CLI session.
Aug 23, 2007 | Lucent Cajun P116T (108360843) Networking...
How can I reset it back to original configration
Hey Eric, I do use same Avaya switch at my lab at office. To me what you have to do is quite simple, first of all you have to get from your network administrator the following info: - Free IP to assign to the switch - Subnet - Gateway (If you ping such IP from a machine of same subnet, there will not be an answer). Then log as superuser (#) and do this: 1. Type set interface inband Replacing , and with the VLAN, IP address and netmask provided by your network administrator and press Enter. (for VLAN you can list them and decide which one to use, but normally you should use 1) 2. Type reset and press Enter to reset the stack. 3. After the Reset, perform login again as superuser.  4. Type set ip route , replacing and with the destination and gateway IP addresses. (If you want all packets not from your subnet to be send to the gateway, then use 0.0.0.0 as destination, list routes set on device for more info) 5. Press Enter to save the destination and gateway IP addresses. That's all. Your switch will be rechable from your same subnet and from other networks if your gateway is working properly and there's no other element blocking you the access. Good Luck!
Oct 23, 2006 | Lucent Cajun P333T Networking Switch
Lucent Cajun P333T Networking Switch Logo
1,640 people viewed this question
Top Lucent Computers & Internet Experts
D. E. Hev
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
