Question about Maytag MGR5751AD Gas Kitchen Range
HELP PLEASE MAYTAG MODEL MGR5750 THE STOVETOP WORKS..THE OVEN DOES NOT. THE GAS WILL NOT EVEN KICK ON. THE ERROR CODE IS F1. IF U CAN HELP..PLEASE DO' THANK YOU
  • Anonymous Nov 17, 2008
    I have the same problem, I have sent an email to Maytag for help, and waiting for response. My extended warranty has expired 5 month ago
  • chalmous Nov 17, 2008
    I have the same problem, but the error code is F3.
    Can't get any help.
    I pressed cancel, unplugged and waited 5 minutes.
    When I plugged it back in, the error cleared, but as soon as I attempted to bake, the error code returned.
    Master:
  • 518 Answers
The manual says to press "cancel" to correct an F# fault. Then if that doesn't work, unplug AC power for a few minutes and try again. If that doesn't work, the unit needs serviced by a professional.
Geno
Posted on Mar 11, 2008
Have a F1-2 error for my maytag range.. the stovetop works fine but the ovens don't
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness.
Jan 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Apr 27, 2010 | Maytag MGR5750 Gas Kitchen Range
I have a Maytag Advanced Cooking System Model #MGR5745ADA that is showing a code "F1" on the display. The oven doesn't work.
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 25, 2009 | Maytag MGR5750 Gas Kitchen Range
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
Maytag MGR5750 Gas Range Oven Door Lock
Hi, I'm Neil
It is a fire hazard! Be Careful!
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Aug 24, 2008 | Maytag MGR5750 Gas Kitchen Range
Have Ilve oven but have misplaced the manual and we need to know the self cleaning program instructions
Here's the user manual for the Following Maytag Range Models (It covers MGR5710 • MGR5720 • MGR5729 • MGR5730 • MGR5755 • MGR5750) =>
http://shared.whirlpoolcorp.com/assets/pdfs/literature/MGR5710ADQ.PDF
Aug 10, 2008 | Maytag MGR5750 Gas Kitchen Range
F3 error code
f3 is the code to replace your oven sensor most you replace by pulling the back panel and removing the scerws
Feb 17, 2008 | Maytag MGR5750 Gas Kitchen Range
MAYTAG GAS RANGE MODEL # MGR5750 ADW
The range has sensed a runaway temperature. if you have a meter you can ohm out the temperature probe make sure it reads around 1270 ohms. if it is way off replace the temperature probe if it is close to 1270 replace the EOC. (Electronic Oven Control)
Dec 15, 2007 | Maytag MGR5751AD Gas Kitchen Range
Maytag MGR5751AD Gas Kitchen Range Logo
104 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
