Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
My Hitachi colours are all messed up, it seems that the convergence output IC's has shorted out, can this be fix without calling in a repairman.
  • domviss Mar 25, 2008
    green convergence went out by its self
    Sergeant:
    Champion:
  • 375 Answers
Have you ever done this repair before if not call for service and save your investment .
Posted on Apr 13, 2008
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
Hitachi 53" projection
there might be some resistor that shorted
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Our television suddenly lost its colour alignment
Sounds TV got problem of convergence IC failure and you need to replace two ICs in convergence section.
If you are familiar with TV repair and have soldering tools then can fix it by yourself or ask help to local TV tech.
Mar 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Hitachi 51F710 Lack of green in picture
that is a color channel that is broken...
You need to increase the red or decrease the other colors. this is done with small preset controls on the neck board (or inside in the back of the CRT)
if that doesn't help. you might need to send it to a repairman before you get electrocuted (it doesn't matter if its unplugged or not, the crt stores lots of electricity)
Jan 08, 2008 | Hitachi 51F710 Rear Projection Television
Red deflection is way off, picture scrunched into top right corner
call 800-648-6657 order part number CZ01341. This is the convergence output ic. You will need to replace the red convergence output ic IK04.
Dec 27, 2007 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Colors all messed up
The fact that you used the term "magic focus" tells me you have a Hitachi projection set. When the colors no longer line up on a Hitachi projection TV, it means that most likely one of the convergence output IC's has shorted out. Sometimes a shorted convergence output IC will burn up a low value resistor too. I have also seen a convergence IC crack loose from the board and burn up 3 low-value resistors. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The output IC's should be resoldered / replaced and the circuits checked and realigned by a qualified tech familiar with Hitachi projection sets.
Sep 09, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi Ultravision 53"- went blank
If it popped, it may have done one of 2 things, the convergence amps may have gone out, or there may be something in the horizontal output section that is shorted, either way call the repairman.
Jul 07, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53SBX59b Rear projection TV out of convergence
from you bought the tv and notice that it has that stain on the edge you should have taken it back as it was covered under warranty.now it is getting worse it will cost you to get it fix your tv has a factory defect.you will have to call the repair man to fix your tv.good luck.
Apr 26, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
