Sharp ER3110 I have taken the top cover off and cannot see a battery. I have also checked the fuses that lay in the main mother board and power suppyl. along with the fuse in the plug.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 35 Answers
Does the device do anything? Is it completely dead? If it is, then there is a good chance the power supplies have failed. Power supplies use electrical devices called "capacitors" to filter out voltage variations which are created during the process of converting alternating current to direct current. If the capacitors have shorted out, they should have caused a fuse to blow.
Do yu have the manual for the machine?
Posted on Mar 10, 2008
I need help sony dcr-sr78 shutdown itself i need solution
hi,
I understand that the power supply is not working in your camera if you tested with both battery and charger, then there must be fault in side, must open it, measure the dc power from the primary point to the mother board up to where the power supply goes, on the mother board several fuses lays, if any of it open should replace with the same ampere fuse, voltage regulator SMD could be faulty, if you don't get fault in these all, then check the processor chip.
Dec 16, 2015 | Sony Video Cameras
Where is the CMOS battery on an acer aspire x1700 desk top computer
Most motherboards use a coin size 3 volt lithium battery type CR2032.
Ti help you.
Download the manual for your model computer from this WEB site.
http://www.manualowl.com/p/Acer%20Computers/Aspire-X1700/Manual/65650
Feb 03, 2013 | Acer Computers & Internet
I have a sharp lc-42SB45UT flat screen that after a thunderstorm will not turn on any more. Now I am pretty tech savy, and here's what I've done. Checked cable and receptacle and both are good....
You are on the right track--follow the voltages--set has a standby power supply--right at or part of main supply---runs 7/24 so likely was damaged.
likely you will find a open somewhere between where power AC enters set and the bridge rectifier---
some general info:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
bad cap on right and good one on left.
arrows point out extremely puffed up caps that are bad.
May 31, 2012 | Sharp Televison & Video
Reset password
All mother board has a CMOS, complementary metal oxide semiconductor, battery. The main purpose for the CMOS battery is to store the system time, date and bios settings even if the computer is turned off or the main battery dies.
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings.
Apr 20, 2011 | Computers & Internet
How to chang bios settings password intel Dg43nb board i m loss my bios password
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings. (Password removed) now you can set new password for your bios..
Apr 20, 2011 | Office Equipment & Supplies
Had to put my motherboard in a new case, and i have tried to follow the manual but i am still lost as the pc is not powering up? i think i have connected everything correctly but still not getting power,...
make sure the aluminum tower is covering black chip on mother tight with metal clasp on alumnium tower is covering chip make sure fan is properly tight on mother board make sure battery in mother board is in and make sure fuse is in mother board then restart push f2 and start your reboot....
Feb 17, 2011 | Foxconn 760GXK8MC-RS Motherboard
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
Dec 29, 2009 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
No Power
Remove cover. Check that the fuse is good, if it is good, check power from power supply to main board.
Oct 29, 2009 | Sharp R-316FS Microwave Oven
My sharp copier AR-5320 just stopped copying and displaying a H
check main power supply socket and plug for blown out fuse,if it doesnt work open the cover on the left hand side to access the power supply board check the fuses if blown replace with the same rating.
Nov 27, 2008 | Sharp AR-5320 Black and White Copier
Till (cash register)
Can you open the cases and see if there are any batteries inside? The batteries will probably be on a board and look like a coin inserted into a holder. If you are not electrically inclined, perhaps you should take it to a computer store and have them check it out.
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
