Question about Uniden TCX905 Cordless Accessory Handset and Charger Phone
Tru9466 base and tru9465-2 handset
Hello. I have a Uniden TRU9466 base and I cannot seem to register my tru9465-2 model handset to it. I was told that both the bases use the same model handsets and are interchangeable. I've tried holding down the "#" key while the base is in registration mode, and I've tried placing the handset in the base. All registration information has been cleared according to the instructions. What's going on?
  • 1 more comment
  • Incognito1 Nov 01, 2008
    My problem is exactly the same. When I finally charged the phone 20+ hours, I found out my "extra handset" (TCX905) was bought by someone else and returned. Most likely because of this same problem.
    There were 6 Caller ID numbers in it already. And in the handset menu there was an option for "Deregistration". I tried it but it said "too far away from base" on the screen after unsuccessfully trying to deregister. So, nothing the base tells me to do to register the phone works...including pressing and holding the # button. This "extra handset" needs to be reset somehow. Does anyone have a solution?
  • Anonymous Feb 09, 2009
    cannot register handset.
  • Anonymous May 20, 2009
    Same problem and attelpted to reset the phone buth nothing comes up on the screen exc ept " check the owners manual"
  • 3 Answers
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Posted on Nov 01, 2008
You need to simultaneously hold down the red hangup and # buttons for about five seconds or until the handset says de-registered. You can then put the handset into the base unit and it will registere.
I had this problem myself on two Uniden TCX905 phones and that was the solution. I couldn't find it in the manual but verified it with Uniden support.
Posted on Jul 15, 2008
  • tinasman Sep 02, 2010
    I had Radio Shack Cat. No 43-5560 with the same issue. I had bought the two accessory phones on ebay and could not get them to deregister until I held down the 'end' key and the # key, then they deregistered from the old system and I was able to register them with my system.
    Thanks mihans!
    Problem Solver:
  • 5 Answers
The TRU9465 is a SINGLE LINE phone system whereas the TRU9466 is a TWO LINE phone system.
The handsets included w/ the TRU9465-2 look like the TCX905, but they're not. Remove the BATTERY COVER and BATTERY, then look at the inside label. The model # wil likely be "TRU9465," not "TCX905."
Uniden, unfortunately, has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against DUAL LINE TRU9xxx BASE SYSTEMS (i.e. TRU9466, TRU9496, etc.).
This is a deliberate and intentional behavior on Uniden's part. Those same handsets from SINGLE LINE phone systems register fine against predecessor TWO LINE Uniden BASE model TRU8866, where both LINE1 and LINE2 of those handsets work fine when registered to a TRU8866 base.
Uniden sucks for having deliberately crippled TCX9xxx handsets (included with SINGLE LINE base systems) against two line TCX9xxx base systems.
Note: It seems the only real difference between the handsets in the "single line" and "dual line" models is the firmware version. If anybody knows how to upgrade the firmware of the TCX9xxx expansion handsets to the version used by the dual line handsets, that should solve the problem. I have no idea how to perform that firmware upgrade though (or where to find the firmware itself).
Posted on Mar 19, 2010
    Problem Solver:
  • 5 Answers
Another possible issue is that your base needs to be reset clearing any previously attached headsets from their registration. To do this, follow the instructions below:
1. Disconnect the power from the base
2. Hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep).
According to Uniden Technical Support, this is supposedly all it takes to reset the phone.
Posted on Mar 09, 2010
  • Mia News Oct 03, 2013
    This worked for my TRU9496 with one unintended consequence: all the voice mails were also delete........
    New Friend:
    Problem Solver:
  • 5 Answers
The replacement handset MUST be deregistered prior to registering to your existing base. I kept receiving "Out Of Range" messages. None of the other solutions worked for me, but I *WAS* able to successfully DE-register the handset, then RE-register to my old base. This is what I did:
1. As said before, simultaneously hold down the handset red hangup and # buttons for about five seconds.
2. You will see 2 options. Base Unavailable, and Deregister HS. Select the "Base Unavailable", press OK
3. The handset prompts "Base Unavailable?", select "Yes", press OK.
4. The handset prompts "Are you sure?", select "Yes", press OK.
5. The handset displays "handset deregistered".
Now you can go through the normal steps of registering to your existing base.
1. At the base, select "Menu", "Register Handset", and the base prompts you to press the # key on the handset.
2. Press the # key for two seconds. The handset will display "Registering Handset", a tone will be heard on both the handset and base, and the handset will register.
Posted on Oct 16, 2015
SOLUTION for registering new TCX905's to a TRU9496 Base.
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Posted on Sep 29, 2008
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Jan 22, 2014 | UNIDEN AMERICA CORP Uniden TRU 9466 -...
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
How do i record a message on a uniden tru9466.thanks
The TRU9466 isn't an answering machine. Please consult the documentation for whatever make and model answering machine you have on your phone line.
If you require further assistance, please reply to this post and specify the make and model of your answering machine.
Feb 22, 2011 | Uniden TRU9466 Cordless Phone
I can't find the owners manual for tru9466.
You can download and print the instruction manual for UNIDEN TRU9466 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 05, 2011 | Uniden TRU9466 Cordless Phone
How to set the answer machine/
The TRU9466 isn't an answering machine. Please consult the documentation for whatever answering machine you have on your phone line.
Sep 21, 2010 | Uniden TRU9466 Cordless Phone
Need manual for a model TRU9466-2 phone cat#
You can download the complete instruction manual in PDF format by clicking this link
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
May 09, 2010 | Uniden TRU9466 Cordless Phone
You can download the user manual by clicking this link
  • You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Mar 23, 2010 | Uniden TRU9466 Cordless Phone
How do you record a greeting on the uniden tru9466?
Go to uniden.com and look in customer service/manuals. They have it to download.
Jun 29, 2009 | Uniden TRU9466 Cordless Phone
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden TCX905 Cordless Accessory Handset and Charger Phone Logo
2,708 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
