Question about Kitchen Ranges
Amana Electric Stove Error Message Probelm. PLEASE RESPOND!!!
We have an Amana Electric stove. Yesterday I went to change the time because of daylight savings time. When I held in the button for a short while the error "5Ab" displays on the display screen. We can still use the stove, but not the oven because the stove does not recognize any button input from us. Please help! We are attempting to cook dinner right now. :P
  • linda30501 Mar 11, 2008
    I tried to set the time on my Maytag Performa range and an error message, 5Ab, popped up. None of the buttons work now. and I can't use the panel for the oven anymore either. Does anyone have a solution?
  • push and hold the clock button for 3 seconds
Posted on Sep 19, 2008
  • a j fink Mar 10, 2013
    That worked for us!
I've done this 2 times already
Hi Sally, let me try to help you. The category I am seeing is Amana 30" self-cleaning range. You are having clock setting issues. I need to know the model number to be able to research the issue and get back to you. Please add the model number with a comment on this question. Don't enter a new one as this will confuse others. I will get back to you as quick as I can with either an answer or to let you know what I can or can't find out on the issue.
Oct 22, 2015 | Amana 30" Self Cleaning Electric Range...
Owners manual amana stove
Try turning off power to stove for a few minutes then re try
Jul 15, 2014 | Amana 30" Self Cleaning Electric Range...
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore electric range 9621 shut down
check inside the stove for some kind of fuse , also check with a multimeter set to OHMS the circuit breaker of the stove to see if theres continuity . hope it helps
Apr 21, 2008 | Kenmore 96213 Electric Kitchen Range
AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
305 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
