Question about Brother HL 1440 Laser Printer
Out of Paper
I keep getting an "out of paper" message and I've tried everything I know:
Powering Down and up again
Removing the paper and replacing
What else is there?
  • Maria54 Mar 13, 2008
    Although I appreciate knowing that the sensor is damaged, I was wondering if it's something I could fix myself.
    Thanks for your help
  • 47 Answers
The sensor of your printer is damaged
Posted on Mar 11, 2008
  • Darrel Barde
    Darrel Barde Mar 14, 2008
    no you need a technician for that
When removing the document that prints, how do I remove it from the continous paper without wasting a sheet every time?
Press the view button tear off the paper then press view button again and the printer will bring the paper back down, I think anyway
Mar 23, 2012 | IBM 6400 Matrix Printer
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Lexmark T650 paper jam message 202.03 open rear door as suggested, no jam, can't clear message and continue, tried powering off etc.
When you remove the back cover you'll find the fuserunit. Ther are 2 "sensorflags" at the exit of the fuser. 1 of them is stuck. Try to make it move again and the machine will work.
Mar 09, 2011 | Lexmark T650n Laser Printer
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
I have Lexmark x85printer. Bought new Ink Cartages. Printer Will not Feed Paper All I get is paper jam Clear paper
Either the ink cartridges are incorrectly inserted, and block the paper path jamming the paper, or the paper drive roller got slightly out of kilter when replacing the ink. Sometimes, powering down the printer, manually moving (gently) the printer head halfway from home position, closing the printer and powering it on will clear a roller problem (never tried on a Lexmark, though. It works on Epsons and HPs). If the head doesn't move, though, don't force it. Try instead taking out the ink cartridges and putting them in again, without forcing, and gently wiggling them until they click in place.
If you get the message without any paper in the printer, check the insides for any scrap of paper which could have lodged in the sensors.
Also, verify there is no paper elsewhere in the paper run (paper out tray, etc.). Sometimes the "paper jam" message is a sort of "catch-all" error.
Nov 04, 2009 | Lexmark X85 All-In-One InkJet Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
CANON FAX MODEL L220
Hi Greg.
Press the red STOP button.After loading paper.
Nov 07, 2008 | Office Equipment & Supplies
Set paper again/toner again error message
I had this problems and did everything suggested on here. Installed firmware update (which just changed the error message - didn't get rid of it), removed paper, changed size, replaced paper, tried new cartridge. Nothing worked. Finally found a tiny piece of paper that must have been blocking the sensor. It was on the left side near where the power cable is. It was less than an inch square. Got it out with some tweezers and problem solved.
Oct 17, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Brother HL 1440 Laser Printer Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
