My control board burned out twice on my neptune washer. today, i received my new control board in the mail so after i replaced it in the same order i took the old one off and it started okay, but the water kept runnin so i turned the dial to drain or spin it and it burned out.
  • 129 Answers
Good day.
I think you need to check first for the water leevel sensor that determines the volume of water required for the certain operation before you are going to replace your control board. Also, look for possible short circuits along the wires to the starting capacitor to the motor.
chris
Posted on Mar 11, 2008
My maytag washer does not spin out, the clothes are still wet
if it is still tumbling in wash cycle,the motor and motor control board on the bottom are OK.The problem will be in the main control board in the top consol.board should then be replaced.If tub is not moving at all it could be the motor control board located on the bottom of the machine in front.When this board goes bad you can usually see signs of burning parts on the board.This part will be replaced with an upgrade kit consisting of a new board and new drive motorfor around 275.00 approx
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Feb 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
LR CODE ON A NEPTUNE 55OOBWW WASHER
Hello there:
The LR error on your non-spinning Maytag Neptune is usually, thoughnot always, accompanied either by a burn spot or a blown fuse on theMotor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge)Either way, it means just one thing: a new motor and motor control board kit are in your future.
Hop this is very helpful for you
Best regards Michael
Dec 29, 2009 | Maytag Washing Machines
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mlg2000aww door will not lock or spin
Removing the top cover of the dryer, you will find, in the front right, the machine electronic control board with a burned resistor. This resistor burns up when the washer lock motor fails. The lock motor and control board will need replacing. Parts cost will be around $220.00.
Feb 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune washer
The R11 burns because the wax motor jams. If the R11 is burnt, it is time for a new circuit board. These are availible on line from the manufacture or at local appliance stores ( I use first source parts). To forwarn you, circuit boards can be pricy. Once you have the circuit board, it is just a case of unplugging on connection at a time and plugging it back in to the new board. To replace your wax motor, you firs must take the 4 screws out of the door frame to the right and left as you open the door. Once you do that the front panel will come off. Then you must remove the 4 screws from the dispenser door. Finnally, you must remove the the 2 5/16 screws holding down the lid. It will then lift up and the wax motor will be right at the front.
Jun 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Apr 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
12002535 wax motor, order online from any part warehouse local sears will do it as well, why do you need that??? just curios as to why you would be replacing that particular item, di you replace the control behind the console already??? if not check it for burn marks just above the little blue resistor just about in the middle of board
Feb 09, 2008 | Maytag Neptune Washer
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune 98 burning smell
check to see if the door boot is intact. if there is a hole in it water could be getting to the motor control board and you are in danger of shorting the machine out. the other possibility is the main computer board may be on its last legs and is doing a slow sizzle
Sep 18, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
