Power supply
Is this by chance a computer power supply? Does the computer come on when the power button is pushed? If so, then the fan itself is bad- bearings are stuck/lubricant dried up etc. Replacement fans are readily available at low cost.
if the power supply is dead, then likely an internal component has failed. If you have some tech savvy, a voltmeter, soldering/desoldering items & skill, you may be able to repair the supply. A very common failure is one or more electrolytic capacitors, and these may show visible signs of failure- bulged out end, and/or leakage.
ATX style power supplies, used in most machines of the past 8-10 years have both a standby and main section. The standby supplies a low current +5 volts to a small portion of the motherboard. When the pwr button is pushed, the main section comes on, and supplies +5 (Red wires), +12 (Yellow wires), +3.3 (Orange wires), -5, -12. Look here for this info http://pinouts.ru/Power/atx_v2_pinout.shtml
Voltages are precisely regulated, and any substantial deviation (more than a few 10ths of a volt) indicate a problem, especially on the +5 & +3.3 lines.
Anyway, you could make these checks. Replacement electrolytics- use the Panasonic FC series (designed for switching power supplies) available from Digi-key electronics, or equivalents (Mouser electronics another possible supplier).
