Question about EuroTech EWC177 Front Load Washer / Dryer
Urotech EWC177 Combo
It does not properly dry the clothes. I can have two pieces of clothing in the unit and I still have to run the dry cycle at 140 minutes atleast 3 times. The service tech tell me it's fine because hot air comes out. I think the air should be hotter. It worked fine when i first got it. Not even Eurotech techs know what it could be.
  • gabriel_ckb Jun 21, 2008
    I have the same problem. The washer portion works ok but the dryer takes forever.
    Is it possible that for some reason the vapor isn't getting released from the dryer for whatever reason? I have no idea what mechanism there is to do this. I am an electrical engineer by trade so I feel like if there is a repair I can do it.
  • monica_enloe Nov 26, 2008
    I have the same problem. I've had the unit for almost a year and this just started happening.
Same problem here and mines brand new. Seems the dryer consists of only a heating element. There's no circulation of dry air. You may as well hang your clothes inside a steam room.
Posted on Sep 02, 2008
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
My machine does not dry properly, very little heat is being delivered to the clothes consequently I am having to hang them to dry. Inez W.
I would suspect that the dryer's heater element is malfunctioning. This would require an engineer visit I fear ;-0(
Good luck, John C
Mar 25, 2011 | EuroTech EWC177 Front Load Washer / Dryer
My clothes come out wet after running for a length of time but they are hot
You have an vent issue..If the clothes are hot but not drying your not getting proper air circulation, you need airflow thru the unit to help remove the moisture from the clothing other wise you end up with warm moist clothing... Start unit and go outside to where the dryer vent comes thru the wall and check the airflow with your hand ,you should feel a good flow of warm air. If not some where between the unit and the vent their is a restriction either in the flex duct or the duct work in the wall which will need cleaned out before the clothes will dry in a normal time frame..Plus it cost a lot to run the dryer 2 or 3 cycles to dry clothes Hope this helps Good Luck
Aug 26, 2010 | Maytag Dryers
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
EuroTech EWC177 Front Load Washer / Dryer Logo
287 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
