Question about TruTech TT1620 DVD Recorder
Getting it plugged in right to work with tv set
No manual. Tried plugging it in, and cable from antenna out on 1620 to tv. TV tuned to channel 3. Nothing.
    New Friend:
How could i put the tv on video with no remote???
Posted on May 06, 2014
You dont put it on channel 3 like a vcr. you put it on video input like you would when playing a game.
Posted on Mar 11, 2008
How do you set up an SP-813 indoor TV antenna?
There's not a lot to this antenna; nor much in the way of knowledge required to set it up. Connect a length of coax cable from the F type screw connector on the antenna. Connect the other end to your TVs antenna input. Plug in the power adapter. Switch on the antenna and set the gain adjuster to the half way position between min and max.
Now look at your neighbours properties. Which way are all their antenna pointing? Point yours in the same direction.
If you know what channel on the tuning scale the local TV stations use for broadcast then tune your TV manually. Then fine tune gain and direction of the antenna for best reception. If you don't know the tuning channel it's a bit more pot luck. Let the TV do an auto tuning and hope you have not too much or not too little gain and the antenna pointing in the right direction.
Sep 03, 2014 | Televison & Video
I have tried to tune my tv but its still not going even when i put the cable in the right place.! it just shows no channels at all.! what can i do?
In your "Channels" menu, you should have the option of "auto tune". Once you've plugged in your antenna, cable cord, select this option. Before doing so, unplug your tv ONLY and let it set for about a minute. Plug it back in, turn on, go into Channel Menu and select the "auto tune" option. This may take a while, as newer tvs have several hundred channels. This will auto tune your tv to the channels received through your selected device\cable. You may consult your user manual for further assistance. I just did this with my tv a couple weeks ago and its very simple. You will also be able to "delete" channels that do not come in well, or not at all i.e. The "ant screen" etc.
Aug 29, 2014 | Televison & Video
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
The only channels available are throu ch 2-13, I have tried doing numerous auto searches. and have tried to restart it. I checked the cable, everthing is plugged tightly and nothing is frayed. It has done...
Make sure the TV is set for "CABLE" or "CATV" tuning. I forget on this model exactly where in the menus the setting is. Sorry. But it's usually in a general setup page, or part of the channel setup. If the TV is set for "AIR" or "ANTENNA" tuning, cable channels 14 and up won't be detected.
Jan 13, 2011 | RCA TruFlat 27F520T 27" TV
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
How to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Dec 19, 2008 | Televison & Video
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Vcr won't record tv
You have to plug the antenna to the VCR, in the "Antenna IN" plug, from there it goes to the "TV OUT".
You use the VCR to tune the TV and choose record according to your VCR model.
Hope That Helps!
Jan 26, 2008 | Televison & Video
Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Oct 21, 2006 | RCA F32632SB 32" TV
TruTech TT1620 DVD Recorder Logo
134 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
