Question about Philips 60P8342 60" Rear Projection Television
Philips 60P8342 60 in. Rear projection tv
Its coming from the rear. i took the back off and theres a pin hole where the three red wires go into a black plastic box. i don`t know what it is. is it the power supply. i looks like it it arching from the pin hole to the ground. ?????
  • Philips Master
  • 8,617 Answers
Thats the High Voltage generator. We have a new one on our site for 53.99 and offer overnite shipping for an addittional 25.00 we also include step by step instructions on how to replace the component. Here is a link to our store. I moved it to the front page so you can see the picture of it. thats the part youre needing.
http://servicemanuals.vstore.ca/
Posted on Mar 11, 2008
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
I need to change the flyback of my TV Philips of rear projection model 50P8341. I do not Know how to remove the damage flyback. First, I tried to remove the anodes that are connected to each of the three...
Leave the CRT's alone!!!!! You will ruin them. The red wires come out of the Fly-back. Pull the rubber caps up and then with a twisting motion pull each red wire out 1 at a time.
Apr 27, 2011 | Philips 50P8341 50" Rear Projection...
My husband placed our Philips 50P8341 Projection TV on its back in order to replace the casters on bottom. When he put tv back to upright position and turned it on all we see are red and green lines. We...
you need to reset your convergence, if you have the original remote, is there an auto convergence button, if not go to the menu and do it manually, align the colors and the lines will go away
Aug 11, 2010 | Philips 50P8341 50" Rear Projection...
Spark
The black unit is the high voltage transformer and splitter and it has possibly cracked causing high voltage to leak out. Unless you have a heavy duty soldering iron and good with multiple solder connections, it may be best to have a technician check it out for you. I would guess it would cost in the $200-$300 range. Thanks for using fixya.
Dec 25, 2009 | Philips 60PP9202 60" Rear Projection...
Picture looks like its 3D what is the problem
The D52W20 had an issue with solder joints around the flyback. When you take the back off the flyback is on the very left closes to the back of the tv and has a large red wire coming out of it. Looking from the top down you will see three small orange rectangles in a row. These are fuses and one of them is going to be opened.
All you have to do is resolder the pins on the flyback and replace the fuse and you should regain convergence.
Jun 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power issue
yes, I believed it in the picture that you are showing with the three red wired are coming from . should have about 9 to11 pins in a rounded circuial on the board
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Pulled the wires for the crts off. didn't label them correctly help
Yes the first one near the rear of the set goes to the blue crt which if you are looking in from rear will be on the far left and the middle will go to green in the middle and the 3rd or last will go to red on the right. A rule of thumb in this case is alway red on right and green is always middle crt.
Aug 06, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
