Master
- Posted on Mar 19, 2010
Re: My psp was working before but now it suddenly hanged...
Hello :
- Remove the battery from the left side of the PSP while it is still on. The unit will power down instantly. Wait ten seconds and then replace the battery.
- Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
- Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Warnings
- If you would like to reset your PSP while it is working normally, you can do so by going to the Settings menu and selecting "System Reset." This will get rid of all your content and restore the PSP to factory settings (and subsequently remove all of your content.)
Or try this for hard resetting :
- Locate your Power button on your PSP. Push the power button up for 10 seconds.
- The PSP will and should shut off. Leave the PSP off for 30 seconds.
- Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
- Your PSP should be working now. If not, then you may have a firmware problem.
Warning:
- Do not have your PSP plugged into a power supply.
- If your PSP doesn't turn off after 10 seconds (of power button being help up) then remove your battery and wait 30 seconds, and then replace
good luck .
rate please !
