Question about Tascam Audio Players & Recorders
Troubleshooting Tascam Da-40 Dat Recorder
My tascam Da 40 Dat machine is giving the errormsg mecha. com. er. what can i do to reset or fix.
robotek
  • 1512 Answers
SOURCE: need a tec to repair
I can help you if you are in Queensland Australia. :)
Posted on Feb 01, 2008
robotek
  • 1512 Answers
SOURCE: Hi there, Do you know
Hi there
You can get the quick start guide an the full manual from here
Good luck and happy recording!
regards
Graeme
Posted on Feb 28, 2008
  • 4234 Answers
SOURCE: hello i have a tascam
Since there is movement in the meters, the heads are good. Look first for any cables or connectors that are loose. There is an "output" section in these that can fail. I don't recall whether this section is an IC or discrete components though. Check the cables and connectors and update this with what you find. I'll look up this model and find the output parts.
Dan
Posted on Mar 31, 2008
SOURCE: Tascam 238 tape deck
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Posted on Oct 12, 2008
SOURCE: tascam da-30mk2 keep getting error
On the top of the cassette mechanism there are two micro switches on one small plate with 3 wires. These switches "tells" the electronics where the door is open or close & activate the rest of loading mechanism (second motor). If only one of the switches is not working, you will get this error (that's was my problem). The switch who is responsible for closing was broken. I replace the switch and everything is working fine and smoothly now.
Posted on Apr 13, 2009
How do I fix a Tascam DA-38 Multitrack Recorder?
It needs cleaning and new belts some of which are very hard to find because they are smaller than a dime. It can be fixed if the Pinch Roller is not cracked.
May 30, 2015 | Miscellaneous
My TASCAM DA-20 Mk II DAT doesn't play back any of my tapes. It still appears to record OK, but there is no level meter or sound or track finding when playing back, though the tape seems to be run
Hi Julian,
There is a lot that can go wrong with these miniature helical scan systems. When I had units like that I packed them off to Russ at New Jersey Factory Service and they were restored. I am not sure about parts like drums at this point but Russ is your best chance to get it working again. He has corrected CDRW and DAT as well as just about anything Tascam makes and he even fixed some Sony units too. I know him as the counterpart to the Chicago Factory Service facility when it was open. He was the Manager in New Jersey then.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Wed 8-4 Thurs 8-3(July-Aug) Closed Fri Sat by appt.
Aug 23, 2012 | Tascam Audio Players & Recorders
Hi, My TASCAM DA-20 mkII DAT recorder is holding onto a tape. It will play the tape and there are no error messages, but the tape will not eject. How do I get the tape out without breaking the DAT...
A Technician usually has to get a tape out of a machine when this happens. In radio when I was Chief Engineer for several stations in Chicago I would send my defective decks to Russ at New Jersey Factory Service in Emerson NJ. He knows how to fix these units.
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Dec 31, 2010 | Tascam Audio Players & Recorders
Where can I get tapes for a tascam da -30 mk2 and what are the tapes sizes?
You need what are called "DAT TAPES". Just like Blank analogue audio cassettes they come in a range of lengths fro 15min to 180min. You'd be better off to use something like a 60 or 90min IMHO. Dat tapes can be purchased from places like "studio spares" or any other PRO media supplier. They can be quite pricey. I tend to buy mine in bulk on ebay.
Before you ask, not there are not different tapes for different machines, but the btands do vary. I use either HHB or AMPEX. DO NOT USE COMEPUTER DATA BACK UP CARTRIDGES as a cheap alternataive.....they are different and end up giving you a lot of loss and errors over the years...sometimes instantly (Tale it from experience!)
Best Of Luck
Sep 07, 2010 | Tascam DA-30MKII
I am having problems with my Tascam Da-88 8
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
May 31, 2010 | Tascam HHB DA30 Tape for DA-88
I have a Tascam DA-30 which ejects the tape
Many different things could sause a problem, belts, mode switch, capacitors in capstan or head motor drive circuit. Hard to say what exactly is wrong with the machine without looking at it.
Dec 03, 2009 | Tascam Audio Players & Recorders
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Need a tec to repair
Jan 19, 2008 | Tascam 122MKIII Single Dual Cassette Deck
NEED TO FIND A REPAIR SHOP YEP I NEED A FIXYA
I'm in Vermont and have 25+ years into it and good references
painintheamp@yahoo.com
536 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
