Question about Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher
Flashing green light
Hotpoint switched on.
Starts to drain and drains for 2 minutes.
Green light second from left starts flashing and nothing else happens.
Won't let you reset to any other programe
  • 57 Answers
Hi there. It looks like water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Posted on May 23, 2008
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
I have a Kenmore Elite Dishwasher Model 665.172824000. We think it stopped part way throught the dry cycle. The green "Clean" light has been flashing since in 7 flash cycles non stop. I tried pushing...
So sorry but the partsdirect site for sears locked down my computer. Check where the drain hose connects to your pump and see if there is a small device the hose connects to that has 2 wires going to it. If it does unplug the wires, turn power off, wait 1 minute and turn power back on and see if it works with this disconnected. If it does you will need to replace this. It is like a sensor that says there is too much debris. Stupid part that was totally unnecessary in the first place. Sorry about the inconvenience.
Feb 07, 2010 | Dishwashers
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Used some washing up liquid instead of dishwasher tablets, after i got rid of all the bubbles and drained it, it no longer starts. If i switch the power off and leave it for a few minutes i can select a...
dear sir vif you have used liquid soap in your dishwasher it will make mountains of bubles to kill all bubles outin a hurry take a sos pad put it in your machine and run the dishwaser this will remove all of the soao instantly try it it really works i am in the dishwasher bussiness and it does work thanks from gilles
Mar 15, 2009 | Ariston Technologies Dishwashers
Green flashing lights , what does it mean ?
I have an Indesit IDL 500, the machine will start fine but after about 20 mins the Ist and 2nd button start flashing. Can you help?
Regards
Ingrid Houben
Jul 06, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher Logo
374 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
