Question about Nintendo Wii Console
Wii Wireless Internet Connection
Kpenguin,
I saw your solution to Figaro1974's question regarding connecting to the internet on your Wii, and thought you might be able to help me with my connection problems. I am using a Netgear wireless router CG814W and am not having any problems connecting with my PC. Do you have any ideas what could be the problem?
Thanks in advance
  • 3 more comments
  • DBerkham May 01, 2008
    I have an Actiontec dsl modem/router and have not been able to get the Wii to connect since its last firmware upgrade.  I was able to connect before that.  I have tried configuring the Wii with specific IP numbers from the modem range,putting in gateway and subnet mask numbers, using WAP security mode but the Internet connection test always fails.  The Wii does pick up the network name (SSID) for my LAN so I know it is not a distance issue.  I've spent an hour and a half on the phone with Nintendo support about this with no solution.  Basically, the support guy gave up.  Can you help?  Let me know if you need additional info.
    DBerkham
    dberkham@gmail.com
  • Anonymous Aug 23, 2008
    error
  • bahamagur Oct 27, 2008
    i am tryin to connect my wii to the internet. other than that i have no clue what i am doing!
  • Anonymous Mar 22, 2009
    i really cant get the internet on the wii because it keeps sayig error code 51030
  • Anonymous Apr 17, 2009
    i have internet in my wii, but now my wi-fi is gone and my internet in the wii dosen't work now. how can i fix it?
    Sergeant:
    Champion:
  • 250 Answers
Have you entered all your settings into the Wii? Gateway IP address, subnet mask, etc? If you have and it won't connect, is the wii too far away from the router to get a signal?
Also check that your router is set to allow enough divices to accomidate your Wii. Is it sending out IP's or do you need to manually enter the IP into the Wii? These are all things you need to check in your routers settings before setting up the wii.
Posted on Mar 29, 2008
  • 26 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
2024
Posted on Apr 03, 2009
Setting up wireless conection to my wii
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6AZS48m
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    Tip
    How to connect your Nintendo Wii to the internet
    In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
    -Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
    -Now select "Wii settings"
    -Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
    -Select "Connection 1: none"
    -Select "Wireless Connection" then select "Search for An Access Point"
    -Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
    -Select the wireless access point you wish to use.
    -If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
    -Select "OK", then "Save Settings", and then "Yes".
    At this point your Wii will now test the internet connection.
    If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
    I hope this guide has helped you connect your Wii to the internet. Enjoy!
    Regards,
    G33k
    on May 13, 2011 | Nintendo Wii Console
    Cant connect to my router netgear
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    How do i connect the internet to the wii???
    Here are step by step instructions on how to set up your internet connection. Please note, the Nintendo Wii connects to the internet via wireless signal, so you must have some type of wireless router or wireless internet connection to connect to!
    http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
    Sep 04, 2011 | Nintendo Wii Console
    How do I get Internet connection on my wii
    Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note that in order to connect to the internet on your Wii, you must have a wireless router or wireless internet connection, via that's the only way a Wii can access internet!
    How to get internet in our nintendo
    Their our 2 options to connect your Wii to the internet.
    The first option is wireless.
    1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
    2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
    3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
    4. Select "Connection 1: None"
        (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
    5. Click on "Wireless Connection" and then "Search for an Access Point."
        (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
    6. Select "OK" and the Wii will display all the wireless networks it finds.
    7. Select the wireless network that is yours.
        (If you're not sure which is yours, or you don't see any wireless networks, click here.)
    8. Select "OK," "Save Settings," and then "Yes."
    The second option is wired internet. For this you must purchase the Wii wired LAN adapter.
    Mar 01, 2011 | Nintendo Wii Console
    How do we connect our WII to our computer? We
    you do not comnnect your wii to computer , if you have a modem supports wireless you need to connect it to your modem , yes you may need to share your computers internet connection if you dont have a wireless router , Regards
    May 30, 2010 | Nintendo Wii Console
    INTERNET CONNECTION
    To connect the Wii to the Internet you will need a wireless router in your home. Otherwise, you have to buy Wii lan adapter to connect it with an ethernet cable.
    To connect, go to Wii settings, then Internet, then Connection settings, then Connection 1.
    Then click wireless connection and then let the Wii search for a wireless access point (a wireless router).
    When your router appears on the list select it.
    If your router has a key, then you have to enter it.
    Press OK and you are finished.
    Jan 30, 2010 | Computers & Internet
    Connecting my wii to the internet
    to connect your wii to the internet connect to the following link or read the following instructions
    http://systemsetup.nintendo.com.au/Connecting_Online
    to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
    a computer connected to broadband internet
    a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
    your wii console to be nearby all of the above
    If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
    if you are using a wireless connection follow steps below.
    Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
    On the next screen, select 'wii settings'
    In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
    Select 'connection settings'
    select an open connection indicated by 'none'
    select the corresponding option, Wired or Wireless connection
    Wired:
    Wireless:
    Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
    the wii will search for an access point, select the access point you wish to connect to, and save the settings
    The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
    hope i helped!!
    Sep 19, 2008 | Video Game Consoles & Games
    Nintendo Wii Console Logo
    257 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
