Problem with Nintendo Wii Console
Wii wireless connection
I'm running in to problems connecting to the internet on my Wii. I tried the solution you mentioned in Figaro1974's question, and wanted to see if you have any ideas.
I'm currently using a Netgear CG814W router which works fine for my PC connection. Any suggestions on what could be causing the problem?
Thanks in advance for your help.
Posted by avatar on Mar 10, 2008
    • By avatardavy spam Aug 23, 2008
    • i dont no which wire to connect to my nintendo wii
Solutions (2)
Best Solution
On your computer Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1
Look for the SSID and write it down.
Also write down the type of encryption you are using. WAP, WEP, or none.
Also write down the security Passphrase.
Also you will need the IP address, in Windows click on Start, Run and enter 'cmd" in the run box.
At the command line type "ipconfig" and record the IP address
On the wii, You should be able to have the wii look for a Wireless Access Point. If that does not work try the Manual Setup in the Internet Connections menu.
Enter SSID
Enter Type of Encryption.
Enter Security Passphrase
Enter IP address
MTU value is not required. Nintendo recommends 1500 if you are having issues.
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wRouter
I am getting error code 51331
Add Your Solution
See all Nintendo Wii Console Problems
