My scren is not showing my info bar on the bottom and there is a one and a hlf inch black line on the right of my screen and ahalf ince black line on the upper portions of my screen and my screen itself if off centered to the left and I cannot see my icons.
    President:
  • 2,351 Answers
You can adjust your display through 1 of two ways.
1. Somewhere on your monitor are buttons that allow you to adjust your screen position, ( left- right-up-down, widen / stretch in both direction, up & down at the same time & left & right at the same time. If you still have the manual for the monitor it will explain how to do this. Every monitor is not the same & each monitor has their own way to adjust monitor positions.
2. This might be a bit harder but all you'll need is youe mouse.
Find an emty space on your desktop, ( yeah I know it's messed up right now, did I mention this would be harder?).
I want you to right click once on your desktop & that will open a small pop-up menue. Left click once on Properties
You have just opened your display Properties. ( I need to mention just like the monitor adjustment screen is different from one to another, your video card will also be different.) My instructions should be close for you to adjust your screen.
So you have Display Properties on your screen. Click the settings tab, than click the Advanced button. Here click the Adapter tab. Look down & you'll see a button ( List All Modes).
Click it. The mode screen will open. There is a scroll bar on the right. Slide the scroll bar down & pick out the setting you want.
Most people use setting - 1024 by 768, True Color (32bit), 60 Hertz
Click Ok & than Apply. Your screen should adjust it's self.
If it does not, than someone messed with the monitor adjustments & you'll have to re-adjust from the monitor.
Posted on Mar 10, 2008
How to fix Westinghouse WD32HD1390 tv when black vertical bar show up on display?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2017 | Westinghouse Televison & Video
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
Vizio display issues
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
My screen is stretched with a 1 and ahalf inch black space on the top and bottom
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
May 13, 2009 | Computers & Internet
The left side of the scren is missing
Try to replace the Logic board first to see it is fixed or not.
Dec 30, 2007 | Philips 50PF9830A 50 in. Plasma HDTV
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
