I have a Go Video R6750 DVD Recorder. The DVD Disc Tray will not open. It appears to be locked. I tried unplugging and restoring to default.
    Genius:
  • 1,665 Answers
Hi have a nice day!
check if some rubber belt is broken
Posted on Mar 10, 2008
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Toshiba DVR19DTKB2 user manual
i have a dvr19dtkb2 video and dvd freeview recorder it has froze on channel 800 tried unplugging it still froze when turned back on can you help please
Oct 12, 2010 | Televison & Video
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Govideo r6750 stuck tray
my 10 year old nephew forgot to take a disc out and inserted another this stopped the tray from opening i had to undo the screws holding the cover and remove them .Good luck p.s. don't forget to unplug firse
May 21, 2008 | GoVideo VR3845 DVD Recorder/VCR
DVD-RAM will not eject via "OPEN" tray command
Hey I just found out how to UNLOCK the tray
Power up the unit, wait for it to read the disc if one is inserted.
hold the stop button and the power button down together for 5 seconds
the display will show UNLOCKED
Open/close button should be restored
Apr 03, 2008 | Panasonic DMR-T2020 DVD Recorder
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
DVD Recorder
sound like a micro glitch try unplugging the unit from the wall outlet and replug in after 30 sec.. should reset the system
Jan 17, 2008 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
