I updated my garmin nuvi 880 and it said to disconnect the unit from the computer and allow it to update before turning it on. I unplugged it and it is in this neverending cycle. How can I fix it? How long should it take to update once disconnected
Try connecting it to your computer via a USB cable. Then log on to Garmin's webiste and download a map update. Then you can put the map update on your GPS to replace the ones you lost. All Garmin customers get one free map update. After than it's about $40-$60 dollars for an update.
Question:
My nuvi 850, 855,
860, 865, 880, or 885 is freezing up or will not boot up past the
Loading Maps screen.....
Answer:
If your nuvi 850, 855, 860, 865, 880, or 885 is
experiencing any of the following symptoms:
The touch screen
is no longer responsive and the unit appears to be locked up
The
unit will turn on however freeze at the point where it indicates that
it is Loading Maps...
The unit takes five minutes or longer to
be recognized by your computer as a mass storage device
A
software update is now available for you to update your nuvi to correct
these issues. Please use our WebUpdater
program to install this update. Please note: Due to this
problem, it may take up to five minutes before your computer will
recognize your nuvi as a mass storage device. This software update will
correct this issue as well.
//changed this line from 'solution1description.innerHTML' to use getElementById
//to prevent FF warnings. They both appeared to work, but this is cleaner.
solution = document.getElementById('solution1description').innerHTML;
Last modified on:
12/21/2009
You need to download and install the Garmin WebUpdater and Garmin Communicator Plugin both available from Garmin's website onto your computer. This allows updates to be installed directly to the 765T and provides the necessay USB drivers as well. The 765T must be connected to your computer when performing all updates or upgrades.
You may need to create a MyGarmin account and register your Nuvi 765T.
Resetting the 765T: with the unit off, press your thumb or finger in the lower right corner of the screen while turning the 765T on. This will clear all user data, base map software will remain intact. Connect 765T to computer and proceed with the Garmin WebUpdater.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
No free maps: but to update software do this:
To download the latest unit
software visit Garmin website: www.garmin.com/webupdater After installing WebUpdater once from the Garmin
website, perform all future software updates from your computer. Simply connect
your compatible Garmin device to your computer, then run WebUpdater from your
computer's "Start Menu" by selecting "Start",
"Programs", "Garmin", and finally "WebUpdater"
Normal
0
false
false
false
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Did you first make sure it was safe to disconnect from your computer before you unplugged the unit??? You first must click on the icon that shows you have something connected to the computer and click the turn it off, or safe to disconnect box and wait for the computer to tell you it is safe to do so. Try that,, and see if it helps you.
I had same problem. I called Garmin customer service who connected me to a computer rep. Garmin hooks with your computer that you have your Garmin plugged into.They can upload the proper software in no time at all.
The rep told me that after I updated my Garmin I might have turned off the unit before it completed updating the new software. You need to wait until the screen with "Where to?" appears.
It works great now. Prepare to wait on hold for a while. I waited just over an hour on Monday, their busiest day.
