Question about Panasonic Lands Phones
Phone do nor ring
My phone doesn't ring when I receive a call. I do not have the user's manual and therefore can't solve the problem!
I appreciate your help
jej
thanks for your message. I solved the problem but actually don't know exactly how!!! I think my son put a 3-number PIN code that I introduced by ramdom. Thanks anyway, but remember that I do not want you to use my email for commercial purposes (ads for example).
I appreciate your collaboration.
jejo
Posted on Mar 11, 2008
Alcatel go phone won't ring
I am not familiar with this Alcatel phone at all. It is my husbands phone. Anyway, he came in and said that his phone is only vibrating and nor ringing. Can someone please walk me through the steps to fix. Thanks.
Mar 26, 2013 | Cell Phones
No sound can't hear on phone and no ring on phone
Hi Wilma,Remove the cell's battery and then reload it again.Check user profile settings and make sure 'Silent's not the selected option.Select 'General' and then customize the settings increasing tone volumes.Make a call and after the person on the other end receives it,press on the ^ up navigation key to adjust the speaker volume.Problem solved?If not,your phone's speaker may need repair or possible changing.Have it fixed in a repair shop.
Hope this helps.Thanks!Please rate this answer.
Dec 13, 2011 | LG Cell Phones
I have a Nokia E5 and since two days ago, my phone doesn't vibrate or ring when I receive a message. It still rings when I receive a phonecall but it doesn't vibrate too. I have tried switching it...
Hi
I think u done something wrong , Go the factory default setting option and put the password Default (12345) and restore the your default setting..
May 05, 2011 | Nokia E5 Cell Phone
The fax line rings and rings but does not pick up as a fax. Is this an issue with the machine or the phone line?
Most likely the machine. This is usually caused by one of two things. Either the machine is set to manual answer, therefor requiring the user to initate the fax reception or the modem has gone bad and is "deaf" to the incoming ring and thus won't answer. Also make sure that the phone caord running from the wall jack to the fax is plugged into the "Line" port on the back of the machine. It should NOT be plugged into the "phone" port.
The display on the machine should tell you wether it is in auto receive mode. You did not post your model but I would check the displey for the word "auto" or similar. If it says "manual" then that is your problem. On some models there is a receive mode light.
Check the phone cord to be sure it is in the line port.
Check the receive mode to be sure it is set to auto receive.
If you have your operators manual make sure distictive ring is turned off.
If all of these are ok then you may have lost the modem board in your machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 22, 2010 | Office Equipment & Supplies
If 13,000 is to be shared between two people so that one receives 3,600 more than the other, how much does each receive?
Let the two numbers be x and y Then, x + y = 13000.........(i) Now, let x = y+3600.........(ii). Therefore putting equation (ii) in (i), we get 2y + 3600 = 13000. 2y = 13000 - 3600 = 9400 Therefore, y = 9400/2 = 4700 Now putting y = 4700 in (ii), we get x = 8300.
Rating the solution is highly appreciated.
Feb 17, 2010 | Mathsoft Solving and Optimization...
How to set machine to receive incoming fax?
Quoted from the manual: The HP all-in-one will not automatically answer calls. You must receive all faxes manually by pressing Start Fax Black or Start Fax Color. For information on receiving faxes manually, see Receive a fax manually. You might use this setting if the majority of calls on this phone line are voice calls and you rarely receive faxes.
This page has more information: http://www.fixya.com/support/p378554-hp_officejet_6210_all_in_one_inkjet/manual-3600/page-86
May 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Can't find my manual.......
THIS is a link explaining how to set distinctive ring tones. You can download the user manual HERE.
You will need Adobe Reader to view the document. Download it HERE for free.
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 12, 2008 | Brother IntelliFAX 2800 Laser Fax
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Lands Phones Logo
56 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
