Canon colour laser printer LBP 2410. Coming up with red light alarm. There is nothing wrong with the printer because sometimes I can turn it off then on again and it works OK. Please help, its driving me nuts!!! Andrew
  • 3 more comments
  • Hoss1976 Mar 10, 2008
    I forgot to mention in my problem above with canon lbp2410, comes up with error code E021
    Andrew
  • Hoss1976 Mar 11, 2008
    The link you have suggested does not seem to work. A message comes up (in Japanese) saying the page cannot be found. Could you please suggest a working link in english?
    thanks,
    Andrew
    Could you please explain this in a way that I can understand how to make the repair? I am not a technician. Is the fault you are describing fixable at home or would I need to take the machine to an authorised repairer (which probably wouldn't be worthwhile - more cost effective to buy a new printer)
    Thanks,
    Andrew
    Please see comment above re please explain repair...
    thanks
    Andrew
    Please see comments above re please explain how to do repair.
    Thanks
    Andrew
  • 818 Answers
Http://cweb.canon.jp/manual/lasershot/pdf/2410-e-user.pdf.
Download this manual and check troubleshooting. cap.7
Sergio
Posted on Mar 10, 2008
    Genius:
  • 1,665 Answers
Hi have a nice day!
I think you must try uninstall and reinstall it using the proper driver according your operating system.
  • 1 more comment
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 10, 2008
    E021 relates to the shift base(unit with the devs on). It is most likely to be the mylar on the tension arm on the shift base drive unit(lives under the shift base) the mylar gets worn & causes the arm to stick (its the one with the big tension spring attached) hope that helps
    Kleanthis Mavropoulos Mar 11, 2008
    I consider that every common user can not carry out with success a repairment at which besides experience, also special tools are needed.
    I would suggest to try to reset your printer. As you probably have not a service manual just do the following procedure and see if error message stops:
    Select [Canon LASER SHOT LBP-2410];
    then, select [Properties] if for Windows 98/Me or [Print Setup] if for Windows 2000/XP.
    2) From [Page Setup], select [Display Printer Status Window].
    3) From the keyboard of the PC, press the following keys in sequence: *, 2, 8, and *.
    4) From [Options], select [Service Mode].
    5) Select the appropriate menu from among the various menus.
    When the machine has started service mode, you must turn off the printer to end it. To return to normal mode, you will have to turn it off and then on.
    Kleanthis Mavropoulos Mar 15, 2008
    Service Call
    When a problem has occurred and the printer does not work properly, the Alarm
    lamp (red) goes on and the service error shown in the figure appears.
    If the error has appeared, cycle the power of the printer using the following
    procedure. The service error message may disappear.
    Turn OFF the printer, wait for 3 seconds or longer, then turn
    ON the printer again.
    If the service error message does not appear, the printer works properly.
    If the service error message still appears, proceed to the next steps.
    Note down the four-digit alphanumeric displayed in the Printer
    Status Window.
    Turn the printer OFF, then unplug the power plug from the AC
    outlet.
    Contact your Canon dealer.
    When contacting your Canon dealer, please report the problems and the
    four-digit alphanumeric.
Canon printer lbp 3310 paper sensor error flashing red when full of paper
my canon LBP printer 3310 the error is alarm light on what the problem
Apr 03, 2013 | Canon i-SENSYS LBP-3310 Laser Printer -...
My Canon lbp 2410 will print in black and white but not colour i have changed the drum cartridge and replace all colour toners Thanks Vicki
Check your printer settings in properties. It may be that the mono black only box is ticked. Untick the box for printing in colour.
May 19, 2011 | Canon LBP 2410 Laser Printer
Canon LBP 3300 printer A4 Paper is already loaded in Cassatt 1 but "Load custom paper in manual feed slot" massage shown when given print comment
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
Apr 16, 2011 | Canon LASER SHOT LBP 3300 Printer
Poor Quality Print
hey,
go to your print software try cleaning the printin threads like red eye removal and all go to ur printer software
BTW UR MODEL
May 13, 2010 | Canon LBP 2410 Laser Printer
Canon lasershot lbp 2410- when it is colour to be printed nothing is printed, some faint yellow only but if set to monochrome it is OK-this printer has made BW 1100 and colour 890 prints. Please help me...
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Canon LBP 2410 Laser Printer
Windows 7 64-bit driver for Canon LBP-2410
hi..try this link ( http://support-au.canon.com.au/EN/search?v%3aproject=ABS-EN&binning-state=model%3d%3dLASER%20SHOT%20LBP2410%0Amenu%3d%3dDownload%0Aos%3d%3dWindows%207& )
Mar 17, 2010 | Canon LBP 2410 Laser Printer
How to take self test page form Canon LBP-2410 printer
Go to printers and faxes, right click on the LBP-2410 go to properties at the bottom and you'll see the print test page on the General tab
May 06, 2009 | Canon LBP 2410 Laser Printer
Canon lbp 2410 windows test page only prints out windows logo in yellow no other colors
no idea how to fix this, I have the same problem!! Have reseated all the toners etc, and if I print in black and white, it prints fine - but when I switch to colour, the only thing that appears ont he page is the yellow corner of the windows logo.
Mar 11, 2009 | Canon LBP 2410 Laser Printer
Canon 2410 error E001
Go to "Additional Functions"
Hit # key
Clear All errors
Jun 10, 2008 | Canon LBP 2410 Laser Printer
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
