Question about Dell W2600 26 in. LCD Television
Dell W2600 TV
Worked for a year... now out of warranty, and will not turn on - no blue power light WILL NOT POWER UP
    Genius:
  • 1,665 Answers
Hi have a nice day!
It is probably a power supply problem. Remove cover and check for a line fuse blown or any burnt component mainly at power supply area.
write a new comment
Posted on Mar 10, 2008
When i push the power on button it won"t turn on . the blue power light flashes yellow three times
Google Dell W2600 blink codes. You're tv is doing a self diagnostic and letting you know what's wrong with by flashing the yellow light. Count how many time and if there is a sequence to it, then look it up.
Feb 06, 2011 | Dell W2600 26 in. LCD Television
My dell w2600 tv turns on but then immeadatley turns off on its own. then it wont work at all after that until i unplug it, then the same happens when i try to turn it on again.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2010 | Dell W2600 26 in. LCD Television
Dell W2600 TV. Picture goes black after being on for 10 min.
http://www.shopjimmy.com/catalogsearch/result/?q=W2600
Back lights invereter or power supply. look for 24vdc on the power supply which is needed for the inveeter board.
look for bad caps in the power supply.
Nov 24, 2009 | Dell W2600 26 in. LCD Television
ARPI your the guru please HELP ME I just need to fix this TV
Dell will replace it if it's less than 3 yrs old but apparently their tech support people are clueless about this and have to be told what they need to look up. The replacement is a nice gesture except if you're like me and paid >$1,000 for this more than 3 yrs ago. I have had TV's > 20 yrs and don't reacall major problems with any.
These instructions were posted on the Dell Community forum http://en.community.dell.com/forums/
The following in and out of warranty TVs (W2600, W2306C, W2606C) with the No Power issue must go through Technical Support to initiate the exchange. Tell the technician to look up the following DSN document IDs to get the details on the in and out of warranty exchange process:
- 313698 Dell-Branded TVs Out-of-Warranty Repair Procedure - CTS/CBG/SMB/GTS-T/DOC. Tell them to scroll down to, Dell W2306C, W2606C, or W2600 TV Replacement for a No Power Issue
- 329986 TVs (W2600, W2306C, W2606C) with No Power. New exchange procedure - TV and Home Theater - Dell Community Forum
* Dell will cover this issue, regardless of the limited warranty status, for the W2306C, W2606C or W2600 TVs for 3 years from the original invoice date
* Once past the 3 year date from the original invoice date, we will not exchange the TV
* Units sent as replacements for this issue should be considered in warranty for 90 days after the replacement or for the remainder of the limited warranty term, whichever is longer
* You will need to provide to them the following information -
TV Service tag number:
TV Order number:
Name:
Shipping address:
Phone number:
Email address:
Reason: Dell LCD TV has the No Power issue
Jan 02, 2009 | Dell W2600 26 in. LCD Television
W2600 click but no picture, no warranty
if power light is lit, the main board needs replaced. It needs to have firmware M016, and REV A07. Thats the latest fimware out there available.
Sep 23, 2008 | Dell W2600 26 in. LCD Television
No power
get yours replaced for free
http://www.dellcommunity.com/supportforums/board/message?board.id=si_hmtheatre&thread.id=2509
Apr 09, 2008 | Dell W2600 26 in. LCD Television
Dell w2600
There is no fix for the W2600. It has a power supply problem.
For sometime Dell was replacing the tv's with new ones, but don't think they are anymore. If you go to the Dell Forum and type in your tv you will see the amount of people that have had the same problem. Unbelieveable. As a matter of fact, Dell is not even making TV's anymore. Guess they gave up. They cannot be fix, cannot get the parts for it.
Mar 20, 2008 | Dell W2600 26 in. LCD Television
Dell W2600
Aug 20, 2007 | Dell W2600 26 in. LCD Television
Dell W2600 TV
I have had the Dell W2600 for about 4 years. My remote for the Dell stopped working after 16 months. Since I was using cable I used the cable box remote. However, about 6 months ago a dark shadow appeared on some parts of the screen but the tv was still viewable. Shortly after, my power light would suddenly go out and then come back on after a minute or so. The problem got progressively worse until tonight it was off for most of the show I was watching and would come back on briefly. I popped the rear cover off and removed the metal shield and found most of the wires on one of the wire harness coming from the power supply board burned so badly the insulation was gone and the plastic connector assembly on the board melted. Because of the nature of modular board construction the power supply board and wire harness would need to be replaced and that doesn't necessarily mean the cause was fixed! To me this is a safety hazard. The TV is definitely out of warranty but I wouldn't expect this type of hazard problem. FYI, the parts I can read are made in China....what's new!
Aug 18, 2007 | Dell W2600 26 in. LCD Television
Dell W2600 Power Issue
>you can try this: Replace capacitor (10uF/50V) on small board >mounted to power supply next to mother board power connector.
didn't work for me. any other suggestions?
Jan 17, 2007 | Dell W2600 26 in. LCD Television
Dell W2600 26 in. LCD Television Logo
160 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
