Question about Roper RAS6233KQ Top Load Washer
Off balance/vibration I replaced the main tub gasket/seal. I put it all back together and now I get a bad vibration. I also noticed a pin that dropped out when I took the tub off but could not find where it went. HELP?!
    Novelist:
  • 131 Answers
The pin probably means nothing. Check all your springs to see if they are connected properly. Then make sure all the support glides are in place. There are three of them. They are plastic, about 1.5 inches long, and slightly curved. There should be one at the top of each of the tub support legs. They can wear out and develop flat spots, causing vibration, but this happens over time.
If it's none of these, is the basket spanner nut tight? Is the drive block in good condition?
Posted on Mar 10, 2008
Hoover 550MA top loader tub starts to vibrate when spin starts and bang into the sides also touches the top.Noticed a rip in the top plastic cover of the tub. The load is balanced and not overloaded.
The top rubber gasket stops water splashing over the top, it also gives some deadening effect in spin. You need that replaced and also check the balance springs and shock absorbers. They do break, come dis-attached or fail.
Nov 29, 2016 | Hoover Washing Machines
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
Oil Is Leaking Out Under The Harminc Balancer On my 92 Jeep Wrangler,4.0 6cyl. I Replaced The Main Seal & Put A New Balancer On & It Still Leaks From The Bottom Of The Balancer
  1. timing cover is leaking oil betwwen cover and block
  2. Disconnect the negative battery cable.
  3. Remove the drive belt(s), fan and fan shroud. If equipped, remove the accessory drive belt pulley.
  4. Remove the vibration damper retaining bolt and washer. Remove the vibration damper using a suitable puller.
  5. Remove the accessory drive brackets attached to the timing cover.
  6. Remove the A/C compressor, if equipped, and alternator bracket from the cylinder head and move to one side.
  7. Remove the oil pan-to-timing case cover bolts and the cover-to-cylinder block bolts.
  8. Remove the timing case cover front seal and gasket from the engine.
  9. Cut off the oil pan side gasket end tabs and oil pan front seal tabs flush with the front face of the cylinder block. Remove the gasket tabs.
  10. Clean the timing case cover, oil pan and cylinder block gasket surfaces.
  11. Remove the crankshaft seal oil seal from the cover by prying it out with a suitable tool.
To install:
  1. Install a new seal in the timing cover using a suitable seal installation tool.
  2. Apply sealer to both sides of the replacement cover gasket and position the gasket on the cylinder block. Cut the end tabs off the replacement oil pan gasket corresponding to those cut off the original gasket. Attach the end tabs to the oil pan with sealer.
  3. Coat the front cover seal end tab recesses generously with sealer and position the seal on the timing cover.
  4. Apply engine oil to the seal-oil pan contact surface, then position the cover on the cylinder block.
  5. Insert timing case cover alignment tool J22248 or equivalent, in the crankshaft opening. Install the cover-to-cylinder block bolts and tighten them to 62 inch lbs. (7 Nm). Install and tighten the oil pan-to-cover bolts to 11 ft. lbs. (13 Nm).
  6. Remove the cover alignment tool and position a replacement oil seal on the tool with the seal lip facing outward. Apply a light coat of sealer to the seal and a light coat of oil to the crankshaft. Install the seal on the timing cover.
  7. Apply a light film of oil to the vibration damper hub seal contact surface. Install the vibration damper using a suitable installation tool.
Do not hammer the damper into place as damage may result to the damper or engine.
  1. Install and tighten the crankshaft vibration damper bolt to 80 ft. lbs. (108 Nm).
  2. If equipped, install the crankshaft pulley and tighten the bolts to 20 ft. lbs. (27 Nm).
  3. Install the accessory brackets.
  4. Install the fan and fan shroud.
  5. Install the drive belt(s) and adjust to the proper tension.
  6. Connect the negative battery cable.
  7. Start the engine and check for leaks
  8. .
Jan 18, 2011 | 1992 Jeep Wrangler
I need to find the timing (TDC) marks for my 95 isuzu rodeo. I had to replace the front main seal gasket. I had to pull the harmonic balancer to get to the seal. I put everything back together & now...
There is no way that could happen unless you did not put the woodruff key back into the crankshaft recess and put crank pulley on random!!!
Apr 11, 2010 | 1995 Isuzu Rodeo
Washer spin off balance
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 04, 2009 | Kenmore Washing Machines
Rear main seal leak in F163 engine
Don't know if there is an updated seal available but if the machine is eating seals that fast you need to carefully check the flex plate that couples the PTO shaft of the engine to the rotor shaft of the generator. If it is bent, cracked, or out of balance you'll eat seals due to vibrating the back end of the crankshaft around.
Carl
Oct 08, 2008 | Welding Tools
Bad Vibrations
new washer time ..inner basket has broken "spider" support on rear new basket and outer tub with bearing will both probably need replacing yellow straps were probably part of original shipping pins
May 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Roper RAS6233KQ Top Load Washer Logo
48 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
