Question about HP PSC 2210 All-In-One InkJet Printer
Ink deposit on the bar below the cartridges
Thre are four sections on the bar and ink is deposited on the two left hand ones
    Novelist:
  • 188 Answers
Hi Autofire,
Please click on the web link given below and try to clean the deposited ink with a soft cloth, you can also use petrol to clean the ink.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Posted on Mar 24, 2008
Using ink cartridges faster than normal.
The picture shows the cleaning resovier. Each time the cartridge pass buy the print head is wiped and residue is deposited there. Looks messy and it is. As for the cartridge usage, they may be an economy selection in your software that may reduce ink consumption. Of course if you are printing in color versus black and white the consumption increases substantially.
Jan 30, 2015 | HP Photosmart Premium C309A All-In-One...
How do I take get the money to come out of the undeposited funds
Which accounting package are you using? The Avanquest Computer Utilities doesn't have an accounting section to my knowledge. If you have Quickbooks, go to Banking (in the Menu Bar) and select Make Deposits. There will be a button to see the funds in the Undeposited list. Check each one and select the account into which the deposits are going. Then click Deposit (or whatever the button is for your version). Then Save, if needed.
I've used Quickbooks 2009-2012. There have been slight differences between the versions.
I hope this helps. Please give more information so that I can double-check the titles/buttons for your accounting software.
(My family business is set up so that I usually enter sales and another person enters the deposits on another day.)
Jan 16, 2013 | Avanquest Computers & Internet
My printer is making the sounds that it is printing but the paper is coming out blank. we have not used the printer before however the ink cartridge looks fine..is there something obvious as to why the...
Hello
Sure the ink in the cartridge is clogged and needs to be cleaned. Follow the steps below
1. Open the cartridge access door on your right side of the printer.
2. Remove the cartridge from printer
3. Take a tissue paper with a little water
4. Wipe the nozzles of the cartridge gently
5. Wipe again with an dry tissue and you will find ink deposit on the dry tissue
6. Install back the cartridge in printer
7. Use cartridge cleaning option in the printer.
You are done.
Jul 21, 2011 | HP Photosmart A516 InkJet Printer
Try to print and it comes out blank. Have replaced both ink cartridges.
This sounds to me like either there is still a plastic cover over the bottom of the cartridges, or more likely that the print heads which are part of the printer, need cleaning as dried ink can quite often clog them up. Check for any ink deposits around the bottom of where the cartridges go in, also, dab the cartridges onto a piece of tissue paper very lightly to check that the ink is coming out.
Jan 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Changed from cartridges to cont. ink system. Now
Hi Dave,
Chances are the problem is that you haven't removed the travel plugs that allow air into the reservoir part of your CIS. This is vital because the air needs to replace ink used up in printing and if it can't do this the air creates something of a vacuum that holds back the ink.
Also worth checking that you haven't got any crimped (folded) tubing or clamps that are still engaged that shouldn't be.
Hope that helps..
Mar 26, 2010 | Epson Stylus Photo 2100 InkJet Printer
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Hp officejet r40 cartridge carriage blocked
Not sure about r40's, but look here about the leaking ink solution for G85's and DJ900's: http://www.fixyourownprinter.com/forums/inkjet/22399
There is a guy named BERT who is a master a fixing HP units, and his email can be found in the above mentioned forum note.
Dec 31, 2007 | HP OfficeJet r40 InkJet Printer
Cleaning of cartridges
try 70% of isopropyl alcohol on a tissue paper. wipe it gently. see to it that some or the ink deposit would melt to it! if it does, try to submerge only the head part of the cartridge!
Dec 06, 2007 | Canon PIXMA MP160 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
