Question about Pioneer DEH-P9600MP CD Player
Im getting no power to my deck
The deck just stopped working. there is a wire that is just hanging not connected to anything. Its connected to the deck and it has a fuse on the wire with a little black box. Where does that go?
    Genius:
  • 1,066 Answers
To the battery
Posted on May 17, 2008
Im adding a alpine cda9884 headset with a ktp-445 already installed on it into my 96 grand cherokee. I am. Going from the ktp445 straight to the speakers. My problem is i cant get anything at all out of...
how is the signal going from headunit to the power pack? Should have a harness from the power pack to the deck (h/u). then out to the factory harness in the jeep. remember there is an amp under rear seat so you need to bypass that to make everything work. yes the blue/white wire from deck to blue/white wire ath the power pack (amp) should be connected in order for the power pack to turn on.
Oct 20, 2010 | Alpine KTP-445 Car Amp
Deck turns off when i hit a bump in my car
A couple things...but the deck must come out to check. (assuming this is a 12v N.American car) If you cannot remove or you dont know how - take it to a car stero shop. Electrical fires are nasty!
  1. Make sure there are no open wires and connections are tight and taped (badly crimped connectors will hide loose connections)
  2. Make sure the deck is supported in the back-it should not wiggle around.
  3. There should be a wire firmly connected to the chassis of the car and the back chassis of the deck - Please do not drill into the deck - use an existing bolt !
Nov 07, 2009 | Pioneer DEH-1100 CD Player
Jvc deck same problem, powers on and functions but no sound
the car is equiped with an amplifier. there is a black wire that you didn't connect. just connect it to the blue with white wire from your radio and it should work.
Sep 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
Cluster lights blowing fuses - Temp gauge stopped working
try changing the headlight switch,I had a similar problem only mine happened after I accidentaly short out when I was replacing the horn pad and for some reason when I replaced the headlight switch the problem went away.
Jun 12, 2009 | 1987 Ford Econoline
Constant Power wire draining battery HELP!
Okay, I think I have it. The red and yellow wire into the deck need to be connected to two different power sources.
The red wire should only be hot when the accessory switch is on. The yellow wire is for constant power to maintain memory in the deck.
Connect the red wire to a source which is only hot when the ignition switch is in accessory position -- that should solve the problem.
May 06, 2009 | 1984 Lincoln Town Car
I get power but nothing else
I am not 100% sure.... but usually the blue wire is a trigger. It is usually used by the deck to turn on amps or power antenna. I would consult an expert, but it may be that your main deck has to trigger the DVD to make it work...... but if I am wrong, grounding this wire WILL FRY your deck, so make sure you do check, what you can do is use a volt/ohm meter and check for voltage coming out of the blue wire when the DVD is lit up, if it is a trigger out it will have a voltage reading of 3-6V IIRC, if it has no power at all, it is PROBABLY a trigger in, in other words 3-6V into it, would probably make the deck work.... if it is a trigger in that is......
Jul 22, 2008 | Accele DVD9520
Auto amplifier installation
Does the new deck have a blue wire for remote and a blue/white wire also? The blue one is for a power antenna and shuts of when playing discs or axillary inputs. The blue/white is for power amplifiers and stays on when the deck is on. Also be sure the remote wire that goes to the amp is not pinched and grounded out to the frame of the car. Let me know, and be sure to leave feedback or I don't get paid.
Sep 30, 2007 | Car Audio & Video
Power to unit but not working
First of all, if you connect iginition and constant to the same wire, it sometimes will not work, make sure they are hooked up to dedicated wires in the car. Also once they are connected and the car is on, press the source (src) button or am/fm button. Check the fuse on the back of the stereo by the wire harness too. Also make sure yellow is on constant and red is on ignition.
Aug 20, 2007 | Audiovox P88 CD Player
Pioneer DEH-P9600MP CD Player Logo
74 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
