Standby-7 blink code
My sony kde37xs955 continually turns itself off after being on anywhere from 30 min to a few hours.picture and sound is fine when on, or re power has a standby blink code of 7 pause 7. i have done minor research and have come up with... lamp, thermal indicator, power supply, d board- and individual components on d board.i am looking for someone with experience on similar issue to help isolate the problem.
  • miketaikim May 11, 2010
    hello, where is the lamp saety switch at? not power at all, no fans running nor anything else. i am not so sure how long/hours i have the on the lamp but it is 5 years old but didnt use much as second tv set. how can i reset the lamp hours? Do i need to change the lamp, if i do how? by the way as i turn on, green light blinks 9 times than red light blinks 6 times, pulse a few second and red light blinks 6 so on.
    please help!
  • 1,779 Answers
If you have the back off, make sure the lamp safety switch is engauged ( you might not have a model that you don't need to do this with). If your set powers up normally make sure the your fans are running. If anyone of them should lag your set will shut down.
Second: How many hour do you think you have on your lamp? Some sets require the lamp hrs to be reset. It's sad because your your lamp is still operating. Let me know what you come up with.
Posted on Mar 10, 2008
Problem with Sony KDS-60A2000 60
The power supply regulator board has the fault. There ie no repair to this board. You have to replace it as card basis.
This is the picture of the said power supply board to your Sony TV.2_5_2012_4_35_40_am.jpg
Feb 05, 2012 | Sony KDS-60A2000 60" HDTV
My sony big screne started shutting itself off and wouldnt come back on for several hours. Then it would power up and standby flash 7 times and after a few mins the picture would be gone but the sound...
On your tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to (1-866-925-PART
Jan 26, 2011 | Sony Televison & Video
My Sony 42" DLP TV blacks out every 87 seconds. Then the green standby light blinks 30 times then I get picture and no sound. 7 more blinks after that I get sound. In 87 seconds later, it blanks out again...
Please replace Lamp in TV because this lamp is weak in result, causing darker picture and turning off and on TV.
Lamp replacement procedure would be written in user manual and its easy.
I would recommend to buy Sony original replacement lamp for TV safety.
Nov 13, 2009 | Sony Televison & Video
Standby light continuously flashes with no picture or sound
count the number of blinks; you may have to unplug the set and try to turn on again--if it does not blink in a sequence(3 blinks, a pause etc) the set is in shutdown and many things can cause this.
Aug 06, 2009 | Sony KP-53HS10 TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Sony KP-65WV700 DVI-HDTV Issue
Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
From here:
Nov 12, 2008 | Sony KP-57WV600 57" Rear Projection...
My Sony Trinitron TV does not show picture. The standby light comes on and blinks 7 times then pauses and then blinks 7 times. This continues to repeat itself. TV never shows picture or sound. Light...
The usual cause of this is the sensing IC (there are 2 of them) on the power supply board. Sony usually recommends pulling the board and returning it to them for service.
Oct 20, 2008 | Televison & Video
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
