Question about Pentax Optio S Digital Camera
Camera powers off automatically once turned on - lens stuck in out position
I've pulled up the white screen with the on+menu+focus buttons - screen reads:
++ KB359 ++
PR: 03.09.18.20.56
LD: 1.45
MI: 19
I tried the next sequence of buttons; however, once the ok button is pushed, the camera shuts down with the lens still in the out position.
Hi trldg.
My S4, which admittedly is 4-5 years old and looks it, has given me intermittent problems for 2 years or so with the lens sticking out. I have always been able to fix it by power cycling.
However, recently it seemed there was nothing I could do andI was getting ready to junk it and buy another one. Then I searched online and I was able to fix it. I knew nothing about MENU+ON or MENU+FLASH+ON sequences (are there others you know about)?
Anyways, I got the hint from a post which suggested this sometimes happens when the battery is swapped while the power is on. I was fiddling with a bunch of things when I think what fixed it was this sequence:
1. remove battery
2. hold down MENU (or possibly MENU+FLASH; I was trying both)
3. insert battery
Now, my fault was such that the power always seemed to be on when the battery way in. If this isn't the case with yours, then you may need to hold down POWER ON as well in step 2 (which might mean 3-4 hands required).
Things went back to normal after that.
Hope this helps you.
Rob.
Posted on Apr 06, 2008
I trying to hook up the gtd120 to my flat screen i am getting sound however no picture . do i need the s-video wire to see movie? I have all the other wires y-b-r--w. hlep
What you have hooked up(y,pb,pr) is component video which carries the video. The sound is trnasmitted through a different cable, RCA(white and red) probably in your case. You need to make sure taht your component connections are in all the way and are making contact and, taht all three are in the correct inputs on the flat screen. It is easy to confuse the colors and all the connections are close together making it easy to make a mistake, I've done it myself. Once you have established your connections are correct, make sure you go through your TV's menu to make sure you are the right menu screen(TV,DVD, etc.)
Jun 14, 2011 | GE GTD120 System
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
My hp f1903 is blurry and I can´t get it to focus. I´ve tried the sharpness on the monitor menu button and have it at the highest level but it does not help.
You should try setting your PC video resolution to the native resolution of this monitor, 1280 x 1024 @60Hz.
If it still bad then you may need to open it up and inspect the inside for bad parts such as capacitors, burnt marks, etc.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 13, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
Stuck on white screen reading accessorize test
Have you tried resetting it? Press and hold the setting and menu buttons at the same time for about 6 seconds.
Mar 12, 2009 | Apple iPod MA446LL/A MP3 Player
Gateway sheild theft mode display and everythings blk+white
The problem was repaired by, Calling gateway. You pull up the challange code #'s on the monitor. You tell gateway agent the code numbers, they tell you a unlock code. You enter that on your monitor. and thats that! You pull up the challange code by unpluging your monitor then hold the menu button on monitor. plug back in holding the menu button! larrygl.
Jan 26, 2009 | Hyundai L90D+ 19" LCD Monitor
EX-Z40 won't turn on
If the battery is fully charged (solid red light that turns to green) then you are going to have to send it in to be repaired.
Jul 26, 2006 | Casio Exilim EX-Z40 Digital Camera
Pentax Optio S Digital Camera Logo
56 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
