Question about Kitchen Ranges
Maytag double oven with ceramic stovetop. Tried to change the time on the stove. Now display has large and small red numbers displayed and cannot use the oven.
    Novelist:
  • 131 Answers
Unplug the machine for about 5 mins. If it's hard to reach the plug, you can turn off the breaker instead. You should be able to reset the clock normally after you turn the power back on.
Posted on Mar 10, 2008
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
I have just moved into a new house with but i can't get the westinghouse PHL768U oven to work. I need help in setting controls like time etc. I havent got any manual. Please help
Chances are, its been turned off and you have had the power turned back on... I found this out as well, that you need to 'acknowledge' the stove... press the centre button by the clock display, and this should beep.. you should then be able to have the elements turn on, and if you want, set the clock.. See the display, and there will be a small red light, that bounces round from corner to corner when you press the Mode button. ie, if the red light is next to Clock, then you can adjust the clock time etc etc.. hope this helps.. otherwise, we also had to find the Range Power switch going to the stovetop...
Jan 28, 2011 | Ovens
My stove and oven froze with an error of 5ab6 bath or 6ath wont do anything
Sabbath feature.
These stoves are programmed for the sabbath.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Jan 22, 2011 | Maytag MGR6775 Stainless Steel Kitchen...
How do i get rid of a 5a6 6ath maytag stove on screen. I have unplugged and replugged after several minutes - still oven does not function at all...help!!!
To
ARROW pad.
"3".
shut-off.
Other Displays:
stay on USE.
Aug 18, 2010 | Maytag MER5775Q Electric Kitchen Range
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
CERAMIC COOK STOVE TOP CRACKED
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Feb 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
I was setting the clock on my maytag model # PER4311ACW stove/range and then a code "5 A6" popped up on the display and now the oven won't turn on altough the stovetop still works and the display...
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Aug 09, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
