Yamaha RX-V750 AV receiver power problem
I have a Yamaha RX-V750 AV receiver about 3-4 years old. A couple of weeks ago turn on after pressing the on off button on the unit or the remote control and eventually did after pressing the buttton on the unit several times. The next time I used it I it would not turn on I turned it off at tghe mains for a minute or so and just left it on until yesterday when I turned it off and now it will not turn on at all.
I had the same problem, only none of the above worked until someone told be to replace the ceramic cap .022 630v c405 on the sub board, and after this mine has worked fine since
Posted on Feb 23, 2012
    Scholar:
  • 99 Answers
G'day i have had the Same Problem With a Yamaha RX-V750 That i have Repaired...You need to Replace the Three Capacitors On the Sub-Transformer Board...They Hold a Small amount of current to use to turn over the transistors and in turn trip a relay that boots the unit these go dry all the time in these units..replace them and it will work again no prob's
Components As Follows:
2x 2.2 uF 100V (C402) (C403)
1x 1uF 50V (C401)
The relay also could be damaged...or the diode across the Coil you may have to replace these too these faults could have been caused by a surge...or just faulty cheap and nasty components!!
Ben M
Posted on Jul 09, 2009
Yes I had the same problem with a RX V659 replace the 220nf 630v capacitor on the sub board and problem is solved. Thanks.
Posted on Nov 06, 2012
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Mar 30, 2015 | Yamaha Rx-v565 Receiver
How to I tell if my receiver is dead?
It sounds like it is dead, check the manual.
Be sure you have mains power to the receiver, it sounds like that failed. A loose plug or blown fuse could cause that type of problem as well. Here are a few links that may help.
Redirect Notice
Redirect Notice
Yamaha RX V373BL Owner Manual
Mar 02, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
Yamaha RX-V663 turns off right after switching it on
The display of PS2 PRT means there is a problem with the power supply. Could be a voltage regulator gone bad, very hard to tell without getting inside.
Jan 02, 2014 | Yamaha RX-V663 Receiver
Yamaha RX-797 Amp not working
You have too much power being ran to the amp and it's overheating.
Lower your wattage.
Aug 18, 2012 | Yamaha RX-797 Receiver
Any one know if the Yamaha RX-V750 is worth repairing if the left channel for both Speakers A and B is dead?
If you are using it as a theater receiver, I would replace it. The current versions are half the price, still built as strong, and are much more capable of operating today's video and audio needs. If you are using it for "Audio", it's still a toss up.. It's a 200 or so repair and the lineup starts at roughly 350 with more options. Hope this helps
Jan 18, 2010 | Yamaha RX-V750 Receiver
Yamaha RX-V750 wont power up
Check the fuse. You might have had a power surge which blew a fuse. If not, check the fuse for the socket. Reset the fuses for that socket. If it still doesn't work, it sounds like the internal boards got fried, or the power supply got fried. The power supply is replaceable, but we don't know if it is the power supply. To check, connect a voltage meter to the power supply.
Something like this happened to me. I found a new kenwood stereo next to the dumpsters, stickers and all still on it, plugged it in, it worked, shut it off to plug in a speaker, didn't turn back on, months later after leaving it plugged in, turned on, I used it, then shut it off for the night, in the morning the standby light was still on, tried turning it on, but it wouldn't for some reason, unplugged it, then the light wouldn't come on, it was once again sitting on a shelf as a paperweight, one day it randomly came on again, and now it 100% works, and I use it as an amp for my RE audio subwoofer, and its worked great since! The reason this kinda applies to you is because its kinda simmilar what happened to you. Just leave it plugged in, and maybe sometime you will walk by it noticing it works.
Oct 10, 2009 | Yamaha RX-V750 Receiver
Yamaha RX V-663 video output into old Coaxial TV
You need a coax to RCA converter. Do a google search, Belkin makes one, Radio Shack probably has one too.
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
2,336 people viewed this question
 Grubhead
Grubhead
