Question about HP DeskJet 3940 InkJet Photo Printer
Printer not working
Ive been using my printer without any problem however recently when i tried printing the indicator light just keep on blinking,ive tried unpluging all usb and power connectors but then again the blinking just wont stop.Im using HP Deskjet D2300 series.Please help.thanks
  • 1 more comment
  • sjkamble Mar 13, 2008
    I require printer drivers for installment of printer
  • Anonymous Apr 21, 2008
    I have Hp Deskjet 3940 not printing, the lead ligth keeps on blinking.
  • marish_eric Jan 03, 2009
    I can't install my printer
My hp 2300jet ink printer not taking paper,green light only blinking
Posted on Jun 15, 2009
Pl.u suggest
Posted on Mar 30, 2008
Just recently ive noticed that my dome light and my floor lights in my 02 town car continue to blink on and off after i get in and close the door. im currently trying to find the source of my battery being...
remove the earth wire of the battery and place an amp meter in the circuit to get some idea of the current draw. Low current1-2 amps will indicate a light on ( glove box light---boot light) higher indicates a much bigger short possible through a relay coil or fuel pump
Mar 03, 2014 | 2002 Lincoln Town Car
Black ink indicator keeps blinking on my canon mp210 and my computer says it USB is not recognized...ive tried several solutions including downloading software and driverrs for the printer...
do you have enough black ink? Disconnect cable to and from printer to the computer and reconnect. If no luck, clean cartridge using tool button. Alligne cartridge using tool button. good luck
Dec 03, 2013 | Canon PIXMA Office Equipment & Supplies
Canon pixma pro 9000
Him have you try to use other driver
Feb 01, 2018 | Canon PIXMA Pro9000 Printer
Ive a kodak printer esp 7250 i have used it a couple times to print off my photos and its been fine,i got the printer out today and put new ink in ready to photo copy and it is not printing for some reason...
How long was the printer stored before you took it out to use it? You can't store a printer with or without ink cartridges in it. When a printer sits, the ink that is in the print heads settles and dries. Once that happens, the print heads are pretty much ruined. You can buy new print heads, but its usually cheaper to buy another printer instead. The reason it is not printing is probably because the print heads are plugged.
May 12, 2011 | Kodak Office Equipment & Supplies
1500 series all in one.check cartrage or paper light is blinking
Hi There
Try cleaning the Contacts on the cartridge not making proper contact with the print carriage.
All the best Pineworks
Apr 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
Paper Light Blinking
make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
hth,
razors
Feb 05, 2009 | Brother HL 5250DN Laser Printer
Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Feb 21, 2008 | Brother HL 1240 Printer
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
HP DeskJet 3940 InkJet Photo Printer Logo
779 people viewed this question
Ben Johnson
