Front audio connections
Hi can you take another look at my problem please i dont think i explained it properly...i have 8 pin connection (in fact 7 pins ::.:) with no instructions
http://www.fixya.com/support/t436788-problem
    Scholar:
  • 101 Answers
Hi Andy
I have just been looking up audio connectors on intel website
http://www.intel.com/support/motherboards/desktop/sb/CS-020642.htm
This information may help you with your problem. I have not read through it all yet as I have a similar problem with a board I am trying to fix at the moment, but you could give it a try.
Posted on Mar 26, 2008
How connect audio front panel in gigabyte g31 motherboard my cabinet is odyssey plz solve my query Nilesh Bhanushali
hello bhanushali19
my name is ausi.
the front panel audio header pins on most gigabyte motherboards is at the back near the rear usb connection close to the CPU.
find the front audio cables form the front of the case.
there are two rows of pins.
. . . . 2 4 6 8 10
. . . . . 1 3 5 7 9
g31 has hi definition audio
1 is microphone L, 2 is ground, 3 is microphone R, 4 is ACZ-DET (can be left blank as well.)
5 is line 2 R, 6 is fsense1 (line return), 7 is faudio-jd (can be left blank), 8 has no pin at all, 9 is line 2 L, 10 is fsense2 (line return.
hopefully this has helped you.
please vote for me
Jan 18, 2011 | Intel Motherboard
I have a an35n ultra v1.1 motherboard I power on my tower,it does power on but it wont post I dont see anything wrong with cap's cpu was tested and checks out Power supply is good Tryed a new video card...
Hello Phenom, Hi.... to properly run/test a motherboard, you need to make sure this parts are good with no doubt functioning. 1. the power supply, 2. Memory, 3. keyboard, 4. Processor with FAN 5. PC speaker(built on-board or the thumb speaker) and 6. monitor How to test. First remove all motherboard connections. Now reconnect the following. 1. make sure that the power supply 20/24 pin is connected properly to the motherboard (and please test this power supply before making connections. To test independently short green wire to ground and plug the unit. you should see the fan spin) 2. make sure that the 4 pin 12volt power connector is also plug in nice and tight. 3. clean the memory slot using a clean paint brush and the module (DDR/2) terminals (the contacts) using an eraser, 4. connect the keyboard, 5. make sure there is a PC speaker connected. 6. connect the power switch of the front panel, 7. Connect a monitor on the VGA port 8. Power on the PC. 8. Look at the keyboard lights 3 LED momentarily. num lock + caps lock + scroll lock and after several seconds 1 LED light, num lock only. If you reach this part you should also hear a beep. then the POST will appear. If you don't reach this part, start again from the top. do this several times. Still no response? you motherboard is bad.
Jan 07, 2011 | Shuttle AN35N Motherboard
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
I have pront panel audio and usb port but am not able to connect the pin can you please explain me the pin diagram to connect my front pannel usb and audio
depends on what board you have?
majority have the same pin outs tho,
http://www.vistax64.com/attachments/sound-audio/8065d1227471405-realtek-audio-jack-mixup-capture.jpg
there is link to a page that explains both F_USB (Front usb ports) and F_AUDIO (front audio connections)
Aug 31, 2009 | Computers & Internet
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
I am trying to hook up front panel usb ports.
check out this diagram i think it might help you
http://attachments.techguy.org/attachments/107266d1180693321/standard-usb-pinout2.gif
or if the link is unavailable then here is the same info
pins 1,3,5,and 7 are one usb connection
pin 1 = +5V
pin 3 = D-
pin 5 = D+
pin 7 = GND
pins 2,4,6,and 8 are another usb connection
pin 2 = +5V
pin 4 = D-
pin 6 = D+
pin 8 = GND
pin 10 is not used
Dec 04, 2008 | Intel Motherboard
POWER SWITCH
Hi sivaprasanna,
Do you still have your manual? If so turn to page 72 for location.
For a close look at the motherboard front panel led to MB pins look at these two pics.
Location of front panel connections;
Item " A " is the front panel MB pins.
Pic two is the layout for each front panel connection;
The power on jumper uses pins 7 & 8.
Pin 7 is positive & pin 8 is negative.
Good luck sivaprasanna!
Mike
Nov 09, 2008 | Intel D850MV Motherboard
Computers & Internet Logo
75 people viewed this question
Alun Cox
David Payne
David Payne
