Question about Candy AQ130 Front Load Washer
Machine has power but not moving through cycle
On cycle it is either cutting out rinsing or stoping on cycle and not moving any further. You can hear that power is on machine but no further movement.
  • Jackiep1969 Mar 10, 2008
    Will check this out thanks, could this still be the fault as it is now not moving through any cycle but you can hear the power - a very light humming sound... sorry to be a pain:)
  • Anonymous Mar 01, 2009
    further movement.
Hi there. I have a candy cwb110 and the bearing on the motor went. I replaced this put it all back together and now when you set it to wash it wil only spin for 30secs and then it will end it's cycle and do no more!? wil drain it's water fine on that mode just wont run it's wash cycle. motor sounds healthy when it is spining.
Is there a reset on the computer side of things or something i may have done wrong?
Cheers
Wyn
Posted on Jul 25, 2010
  • 4 Answers
It could be the pressure level switch faulty or it's not holdingd air in the collector.
Check : When machine stopped during the cycle check if the switch is open or closed to the timer, it must be closed to the timer not to the filling.
Posted on Mar 10, 2008
Hotpoint wd440 just fills and drains does not move on from wash cycle
it ran for two hours but where did the water go? if it was not cutting off water then u most likely need to replace the water inlet value
Apr 07, 2014 | Washing Machines
Cycle won't start allowing water to enter
This might be the timer that has a bad contact or it could be the water valves are bad or the power to the switched parts is bad.
Dec 02, 2013 | Kenmore Washing Machines
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
Stoping on rinse cycle
your lid switch is bad. can take a pen and push it up and down to hear if it clicks. may want to take it off and see if it has split. very easy to do. if you need help i can walk you thru it.
you can take a jumper wire and try putting it in both ends of the plug coming down off the machine. you can strip both ends of a wire and that will be your jumper. all that is doing is by passing the lid switch. do not put either end in center of plug. plug machine in and make sure the wire is not going to hit against frame and turn machine to spin and on.
any further question let me know,
thanks.
Mar 29, 2009 | Washing Machines
Washer stuck between drain and rinse cycle
Could be stripped teeth in the timer gears. I take it if you move it a little it starts moving again?
Make sure the lid safety switch is engaged by the pin on the lid.
Mar 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine not rinsing
Set your machine for warm wash warm rinse.
If it works OK.
Replace the water inlet valve.
Feb 14, 2009 | Kenmore 22422 Top Load Washer
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Whirlpool washer machine will not spin when the rinse cycle is activated, I hear the switch moving as soon as it starts to move it cuts out...
spund slike a lid switc issue, try opening and closing the lid a few times and as you do listen for a distinctive "click " noise rigth before the lid closes, if you dont hear tha tthe machine is not recognizeing that the lid is down as for safety reasons will not advance to drain/ spin mode. if this is the case youlkl need to replace the lid switch assy
Apr 02, 2008 | Washing Machines
Candy AQ130 Front Load Washer Logo
460 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
