Question about LG Flatron L1750S 17" LCD Monitor
LG L1760TR Problem
Dear Sir,
A yellow vertical line appeared on my LCD
Is this problem can be fixed?
Here is how it appears, when powerd on even when not connected to the PC.
Thank you for your concern
  • a_68 Mar 11, 2008
    Thank you very much
    Champion:
  • 220 Answers
This is a problem of the panel and generally not fixable.Contact LG service center ,Normally a 3 year warranty is provided.
Samir
Posted on Mar 11, 2008
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
A vertical yellow line has just appeared on my LG flat screen monitor. What causes this and is it fixable?
Please review/check the operations/product manual of your LG monitor, as it set-up settings is modified, OR possibly, there might be an internal electronic part/s that are loose/cold soldered in the monitor which I suggest to bring it to an Authorized LG Service Center that will fix the unit. best regards
May 11, 2009 | LG Flatron L1750S 17" LCD Monitor
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Yellow vertical line
most of lines vertical or horizontal are defects in the screen that can't be repair unless you change the lcd screen, which is very expensive, in my experience this lines wont disaperar by any mean that I know, this monitors (all lcd) have a very delicated circuitry that can fail in a joint between the lcd panel and the circuit board (solid board conected by a flexible circuit ribbon to the lcd) unless you have warranty, I think you will got to live with this defect, or change that monitor. hope it help.
note: some hot air in the joints will help but if you dont got experience on this tool could be worst (not recomended).
Jul 29, 2008 | Computers & Internet
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Lightly press on the line at the top and bottom of the screen. If the line goes away while presses then its the TCP connector problem. You will have to open the monitor and use a piece of soft rubber to keep the tcp pressed.
Word of caution: TCP is extremely fragile, so be very careful.
Hope this helps
ARQ
Mar 09, 2008 | Computers & Internet
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
LG Flatron L1750S 17" LCD Monitor Logo
366 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
